by keno on Mon Feb 19, 2007 9:36 pm
HX machines keep the water superheated well beyond normal brew temps so that a single boiler can serve two purposes: steaming and brewing. For brewing water is drawn from the tank through the heat exchanger in the boiler, where it is instantaneously heated to brew temps. For steaming you open the valve to the steam wand and steam immediately escapes from the boiler. If the machine used a thermostat think of what would happen next - the pressure would drop big time and the heating element wouldn't kick on until the temperature dropped enough. Your steaming performance would be terrible. A pressurestat ensures that when steaming the element kicks on immediately and vastly improves steaming performance.
Cheers,
Ken
If not for coffee, I'd have no personality at all.
