roblumba wrote:One thing I thought made a big difference for aging is the oil. Is it kept in the bean or can you see it on the outside of the bean? Since I felt the oils are volatile, they are better kept inside the bean, otherwise, the oils are more subject to become rancid. I thought I read about this somewhere, but I can't remember where.
Oil on the bean depends on roast level. The lightest roasts for espresso (North Italian or Light Full City) will not show oil in the first few weeks after the roast. Darker roasts will either be oily out of the roaster (French roasts) or oil up in about 3 to 5 days (Vienna roasts).
The best degree of roast is a matter of taste and bean type. The Junqueira, for instance, cupped a little gunpowdery, so would not do for a darker roast. Many indos, on the other hand, are at their best at Vienna roasts with oily beans.
The bit about the oils staling more on the outside than the inside of the bean strikes me like a clever bit of defamation Schomer came up with when he was still battling the idea that espresso had to be roasted to Starbucks levels. From a PR point of view, it's better to insist one is right, and the rest of the world is wrong, than to say there's room for all sorts of coffees.
PR and truth don't mix. The oil bit seems like obvious PR to me for a simple reason -- there's no such thing as a dark roast without oil on it; hence, to say visible oil is bad is to say no more than dark roasts are bad. Brewed coffee drinkers tend to disparage dark roasts for reducing the aroma and acidity of the coffee; this is undoubtedly true, but since "acidity" is a scare word for most coffee drinkers, the stale oil bit has legs as a put down.
