Why am I getting NO crema?
Link to "Why am I getting NO crema?"by jthiessen8 on Sun Jun 29, 2008 5:50 am
I am trying out a new (to me) 1 group commercial espresso machine. Everything works great, but, when I pull a shot, it comes out with absolutely no crema. When I use the same coffee on my little home machine......lots of crema. What is the deal?
jthiessen8
Link to "Why am I getting NO crema?"by HB on Sun Jun 29, 2008 10:19 am
Not a lot of information to go on, so let's cover the usual suspects:
  • Is the coffee fresh? Almost too obvious to ask, but I have to ask.
  • Does your little home espresso machine have a pressurized portafilter ("crema enhancer")? They can generate "fake crema" from stale coffee where a commercial unit will fail.
  • Difference in grinders? Cafes are renowned for running burrs until they're smooth as a baby's behind. I once spoke to a cafe owner who was unaware that the burrs ever needed replacing.
  • Pressure difference? If the commercial unit is maladjusted (too low), no crema.
  • Water difference? While unlikely, one could be on water treated by reverse osmosis. RO water is a crema killer.
For what it's worth, I've only managed "no crema" espressos with abysmally stale coffee. Pulling espresso with lots of crema is easy; pulling shots having lots of crema and a great taste profile, that's hard.
Link to "Why am I getting NO crema?"by jthiessen8 on Sun Jun 29, 2008 10:30 am
That is good info, so I will attempt to answer each...
1. Same coffee is being used between both machines. And I just bought it. So it is relatively fresh (i.e. i did not roast it myself)
2. I dont think my little home machine has a presurized portafilter. Just one like any other home machine.
3. I am using the same conical burr grinder for both the home machine and the commercial machine.
4. Its possible the the brew pressure is too low. It has a gauge that is reading "6" bars (i assume), but as I dont have the manual, I am not totally sure about this.
5. Same water source for both.
jthiessen8
Link to "Why am I getting NO crema?"by MachoSilvia on Sun Jun 29, 2008 2:52 pm
A lot of smaller home machines have crema enhancers, look on the bottom of your basket. if it has one hole as opposed to many, it is pressurized, and has a crema enhancer.
Coffee that is bought from the supermarket is rarely fresh. just because you just bought it doesnt mean it's fresh. hunt down a local roaster, and buy coffee you know the roast date of.
just my two cents...
"Join Me, i will teach you the dark side of the force"
MachoSilvia
Link to "Why am I getting NO crema?"by jthiessen8 on Sun Jun 29, 2008 3:43 pm
OH!, I see. Yes, it has one hole in the bottom. Geez, I thought I was just great at producing crema....how humbling :oops:
OK, there is a roaster down the block. I am going to try out his stuff. Thanks.
Also, what controls the brew pressure on commercial machines?
jthiessen8
Link to "Why am I getting NO crema?"by HB on Sun Jun 29, 2008 5:24 pm
jthiessen8 wrote:Also, what controls the brew pressure on commercial machines?
They usually have rotary pumps; brew pressure is adjusted by turning the screw on its bypass valve. The pressure adjusting screw for a Procon rotary pump is shown below:
From Procon exploded view; also see Adjusting espresso machine's rotary pump brew pressure?
Link to "Why am I getting NO crema?"by jthiessen8 on Sun Jun 29, 2008 9:36 pm
Well, you guys could not have been more right. I went down the street here in Portland, OR to Ristretto Roasters http://www.ristrettoroasters.com/ and bought their espresso blend. Roasted on site this last Friday. Should it be more fresh than that? Perhaps they could roast it while I wait. :shock:
The result......LOTS OF CREMA. OK, I learned my lesson...no more skimping on the beans.
Thanks.
jthiessen8
Return to Tips and Techniques
