by Paul L on Sat Sep 03, 2005 6:40 pm
Many thanks Dan, I'll have a go at this tomorrow in daylight. It's pretty late here now.
Well, I couldn't just open the box so I just had to have a play. I put some vinegar-water through on a blank run following the manual about priming the machine and then two further runs of blank water. I figured this would help get used to the mechanics and it's a very different routine from that which I'm used to. I flushed some more and then filled and emptied at the sink a few times too.
It's all the little things about what you do when, what you get ready. After 4 months with the little Gaggia I was starting to fool myself that I was becoming a Barista. I'm sure you know what I mean. Someone comes in and you silently, swiftly and with deft skill go through a routine you do day-in, day-out and put a fine drink under someone's nose. Then you get a different machine and you're back to the beginning, except that you've picked up a bunch of skills along the way.
Round 1: I ground, tamped with the inadequate stock tamper, loaded up, lifted the lever when prompted, waited to see some infusion then lowered. Nothing. Not a drop. What had I done? A choker, didn't allow time for the group head to fill? Absolutely no idea. Not a great idea to use my fresh Guatemalan beans though as I'm not buying much before the i-Roast arrives. Best open the wood-chip stale jobbies supplied with the La Pavoni and let the Macap try and make something useable of them.
Round 2: Grind looked okay, nice wood-chip aroma if a bit dry and stale looking, load-up, lock, lift, wait, drips starting, lower. Yuk, looks like tea leaves when used without a strainer. What have I done now? Ah, I have failed to engage one of the portafilter lips which are smaller than those I am used to on the 58mm Gaggia portafilter so i have failed to get a seal.
All this while the little Cubika is looking at me saying "fancy a cuppa"?
Round 3: Repeat, lift, wait, ah we're getting somewhere, good heavens I think it's working, there's even an attempt at some temporary crema from these old wood chips. Oka, let's froth. Crikey, it's like hanging onto a wild horse compared with the Gaggia, I surf with the 3-hole, it's whipping round and frothing in no time at all, I plunge, it's looking good quickly, onto the coffee it goes. It's actually looking good, none of the trouble that Kaarina has reported.
I clean up, sit down, reflect on the fast operation, the frothing arm that swings up aiding cleaning, the ease of releasing the pressure to remove the cap and let it cool, the joy of having the Gaggia for the mornings and the La Pavoni for playing in the evenings and tuck into the first of many cups I suspect. Hmm, that was fun, shall I go switch on and make another?
