If you can tolerate or perhaps even enjoy the baked flavor associated with air roasting your coffee
chlyonsiv wrote:My popcorn popper died this weekend, so I've decided to upgrade to something that allows me to control the roast a little better. I'm torn between the Behmor and the Gene Cafe', and was hoping that those of you with experience with the two could offer some insight...
The difference depends on the control that the specific roasters present to the user. Both methods are capable of roasting excellent coffee. The problem is that the fluid bed roasters as supplied commercially for home use tend to give little control over the roast and roast too fast, not giving the coffee time to develop.chlyonsiv wrote: I'm also very curious about the difference in drum roasting vs. air or fluid-bed roasting.
Currently, the best home roasting appliance in terms of user control is the Hottop KN-8828B, but if the Gene is too expensive for your budget, this one is out of the question. The Gene's temperature control is quite good. Check my reviewof it as there is a graph specifically addressing ts control ability.What I'm most excited about in using something other than the popper is being able to control the roasts a little better.
Roast level is also dictated by method of brewing and the beans you are roasting. A roast that might be delicious as drip could very well be disgusting as an espresso. Additionally, the level of roast degree is just one factor. The level is the destination, there are many roads that lead there.I've tended to gravitate toward darker roasts, but plan on doing a cupping on the same beans, just different roast levels to really get a sense of how the "experience" of the coffee is impacted by the roast.
Randy G. wrote:Roast level is also dictated by method of brewing and the beans you are roasting. A roast that might be delicious as drip could very well be disgusting as an espresso. Additionally, the level of roast degree is just one factor. The level is the destination, there are many roads that lead there.
Randy G. wrote:Currently, the best home roasting appliance in terms of user control is the Hottop KN-8828B, but if the Gene is too expensive for your budget, this one is out of the question.
chlyonsiv wrote:It isn't so much the cost of one item; it is the cumulative cost of a lot of stuff, over a very short period of time....
My coffee website is exactly one week shy of celebrating 8 years of online activity.
C'mon! Just after first cup, it's already far too late. And good - make a cup for your wife and give her a present and then go coffee-shopping together!Run. Run like the wind. RUN AWAY, NOW, before it's too late.
RAS wrote:If you're dead-set against heat-gunning, I certainly understand, but I would certainly advise anyone interested in roasting to consider it... especially if you like to be really-involved in the process.
Actually, I'm curious about it -- the same guy who introduced me to home roasting apparently uses a heat gun for some of his roasts. I haven't tried it. What do you use to hold the beans? My friend uses an old bread machine that he has modified, which is why I haven't looked too hard at it -- I don't have a spare bread machine sitting around. Where can I find out more about it?
