by cannonfodder on Thu Feb 02, 2006 10:25 pm
Old 49mm portafilter
New 51mm portafilter
More coffee in basket, the larger group also overheats slower. The new version also has a polymer sleeve in the group to help retard the overheat issue, but it still overheats. You get one more shot out of the new based on what I have heard. Important note, I have never owned the old model (pre millennium, the new version is referred to as the millennium edition) so my statements are from what I learned when researching them.
The Millennium edition uses a single power switch; the boiler is controlled by a small pressurestat in the base. The old version has two heat switches. One for brew temp, the other increases the temp for steaming. If the old version is left on it will heat until the pressure relief valve opens. If you accidentally leave it on, it will boil the boiler dry and blow the heating element. The new version will get to hot to brew with, but the Pstat keeps overpressure and heat in check. I have left my new style machine on for hours with no problems (other than it getting to hot to use) and I did that intentionally. There is also a thermal breaker in the base so if it does get to hot, it pops and shuts down the machine. Remove the base, push the breaker and you are back in business.
The new version uses a polly piston as Bill suggests. One positive point, coffee residue sticks to brass like glue, the polly piston stays cleaner longer.
I have heard of chrome peeling off of the old version. I personally think the new versions finish is better than the old, but I have never seen a new old style machine.
Parts for both are readily available, and probably will be for decades.
A new one is ready to go out of the box. A used old style will probably need new gaskets (cheap and easy to replace) and the bases are notorious for rusting if not cared for.
