by chopinhauer on Thu Jul 19, 2007 1:25 am
Re microfoam, be patient. Given a machine is capable of producing microfoam, then actually getting microfoam out of it is a question of technique. And let me assure you the pavoni can consistently produce fabulous microfoam with the correct technique. So once you hit upon this technique, something that can only occur with practice, you'll produce PERFECT foam.
By way of example, I recently got an olympia cremina, and for the life of me I couldn't produce good microfoam on that machine, even though I was an expert at doing so on the pavoni. So I assumed that the cremina was not good for foaming. After much practice, I can now foam as well on the cremina as the europiccola, so my initial assumption re the cremina was wrong. Hang in there and read the foaming guides. Especially important is to make sure the milk begins to stretch the very second you insert the milk wand. If it doesn't then it will burn.
LMWDP #027
