miKe mcKoffee wrote:The optimal window for the green will vary depending on how it's stored. Store in cotton bags in high humidity high temperature without air conditioning during the summer months like the Gulf States and its window would be short indeed.
You've done your research.
miKe mcKoffee wrote:Yes I've heard the theory vacuuming roasted coffee beans sucks out the volatiles. Yet roasts mason jar FoodSaver vacuum sealed directly from cooling and four to six days vacuum rested served to an advanced cupping palate like Tom Owens suggests otherwise. I've done so on multiple occasions.
I think that theory and the ice crystals theory are both armchair quarterback bunk. When you start to research the structure of coffee and really think about it, some of these claims sound silly. It's good to see you do the research and take the time to set up experiments. Big props to you, Mike. That's all we can do, rather than hearsay and opinions, work with facts and data. Take the time to set up the experiment and judge it for ourselves. We must read things like Flament's coffee chemicals book and figure out what is really going on. The results should speak for themselves.
We should abandon this myth that jute bags are fine for a quality coffee. Light, moisture, and heat are well documented in their effects on green coffee and jute adds to the problem instead of helping solve it. Why not someone search about how jute is made and post info as it relates to coffee? It's hard to see someone swearing vacuum sealing may 'suck the aromatics out' then we overlook that the alternative is a big woven sack which in itself may aid in contaminating our beloved coffee.
I will be interested to see how people react to the Daterra packaging for this years Brazil CoE. How many people will it convince about the need for quality packaging? I just saw Paradise's Colombia Tolima lot vac sealed and will be dying to try it when I get back in town. I can pay money for that since it will be more likely to resemble the harvest flavors and I won't miss that 'optimal window.'
malachi wrote:That's easy to do.
Roast it all within the optimal window for the green.
Open your mind. There is room for a lot of differing philosophies and approaches. The educated consumer has the choice, not some purist etiquette about what is right.
another_jim wrote:A lot of this is overdone. For most coffees storing in baggies, jute, or in whatever else the seller used to hold the beans, will work just fine for a year. Floral and highly fruited coffees will fade, and for these you might consider something more high tech.
I'm glad that as usual, you've done the research on this subject before offering opinions. I look forward to you posting your personal results and experience from freezing and vacuum bagging coffees at origin vs jute bag controls.
