What is the best way to do routine cleaning of a la Pavoni group head?
A haven dedicated to lever espresso machine aficionados.
Link to "What is the best way to do routine cleaning of a la Pavoni group head?"by Jarno on Wed May 30, 2007 9:35 pm
I have a question with regards to cleaning a la Pavoni. It seems most people here clean somewhere between 2 and 6 weeks. How do most people clean their group head? The manual recommends using the cleaning agent (Urnex Cafina) into a full boiler and then run it through the head. Are there any who prefer to break down the group head and clean manually, thus getting a better cleaning job, though at the expense of risking some gaskets and o-rings? Or, is there another better way?
Thanks
Jarno
Link to "What is the best way to do routine cleaning of a la Pavoni group head?"by jerker on Thu May 31, 2007 2:33 am
i use a brush (similar to this one http://www.espressoparts.com/product/UB902) after every use (or at least once a day). then i take the group apart about once a month and clean inside. it will take you no more than ten minutes including putting everything together again. here's a good guide (you can take it apart just for cleaning without replacing the gaskets) http://www.home-barista.com/forum...athering%20peacock. then i descale about once a month. i use regular descaling solution (i have heard than vinegar works also but never tried that), fill the boiler and run it through the machine. then i run clean water through twice before making coffee. i don't know if my routines are optimal, but they work fine for me. my machine is always clean and the gaskets last.
jerker
Link to "What is the best way to do routine cleaning of a la Pavoni group head?"by Jarno on Thu May 31, 2007 6:51 am
Thanks. Very helpful
Jarno
Link to "What is the best way to do routine cleaning of a la Pavoni group head?"by espressme on Thu May 31, 2007 10:48 am
Jarno wrote:I have a question with regards to cleaning a la Pavoni. It seems most people here clean somewhere between 2 and 6 weeks. How do most people clean their group head? The manual recommends using the cleaning agent (Urnex Cafina) into a full boiler and then run it through the head. Are there any who prefer to break down the group head and clean manually, thus getting a better cleaning job, though at the expense of risking some gaskets and o-rings? Or, is there another better way?
Thanks
Hello Jarno,
FWW, I use a bit of the commercial product such as "Urnex," "Cafiza" or similar Mixed in hot water according to instructions. I place the solution into a cup measure and ( with the machine off!)present it to the group. Then I slurp ( scientific term) the solution in and out with the lever. After a few minute with the solution in the chamber. I then flush with warm water the same way. Then I can do the boiler and upper group chamber when I wish. The commercial stuff does a great job on the coffee residue and the other cirtric acid and/or vinegar cleanses do a job on the scale.
my 1¢
sincerely
richard / espressme
richard penney LMWDP #090,
espressme
Link to "What is the best way to do routine cleaning of a la Pavoni group head?"by TUS172 on Sat Jun 02, 2007 8:56 am
espressme wrote:Hello Jarno,
my 1¢
sincerely
richard / espressme
This is also my prefered method. It is simple and works very well.
Bob C.
(A lever purist!)
LMWDP #012
TUS172
cron
