I've bought myself a 2nd hand La Pavoni Professional (Pre-Millenium), but it has a weird leak.
When has almost heated up, at the point that the pressure is rising, water starts leaking from here:
(where the drops are shown). When I pull up the lever during this leak, the water starts leaking in a rapid rate, but after i've filled a cup with water by pulling the lever to is highest point, the leaking stops and it won't start again when the lever is down again. After that, the pressure reaches his normal point and I can make espresso without any problems.
Sometimes I can prevent the leaking by filling a cup with water before the leaking has begun yet, but this should be done at the right moment before the leaking. There are even times when the leaking stays away.
The problem is that the grouphead gets incredibly hot during this whole leaking thing, so the espresso is brewed too hot most of the time. At times when it does not leak, there is no problem with the temperature.
I think it has something to do with wrong pressures at wrong places at wrong times. Does anyone recognise this problem? When I've stopped the leak by pulling the lever up and down, there is a powerful downwards pressure from the lever when I try to pull it up again. This pressure seems to prevent the leaking.
Can anyone help me? Any suggestions are welcome!
Cheers,
Eric
