www.eccocaffe.com: custom coffee roasted in Northern Italian style
Vibiemme double boiler PID espresso machine on the way - Page 3
Read about current and future offerings from the site sponsors.
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Thu Feb 14, 2008 2:26 am
- Brew Boiler 1414 ml 100x180 diameter with 3 mm thickness rather then 2,5mm like most of the other boiler
( this avoid the need of a external thermo protection to keep temp stability)
- Steam Boiler 905x180mm thickness 2,5
Err, I read it wrong :oops:
so whatever the volume of 905x180 is.
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by cafeIKE on Thu Feb 14, 2008 2:08 pm
Numbers : SPL @ 1m
C weighting : [ Nominally Flat response ]
Max Hybrid Grinder : 76
Vibiemme 65 during infusion dropping to 61 during extraction
A weighting : [ As we hear ] A weighting on wikipedia:
Max Hybrid Grinder : 75
Less that 60 in both in both cases.
In layman's terms, about twice as loud as the refrigerator.
cafeIKE
Link to "Vibiemme double boiler PID espresso machine on the way"by jasonmolinari on Thu Feb 14, 2008 2:13 pm
Thanks CafeIKE, that gives it a little bit of perspective.
jasonmolinari
Link to "Vibiemme double boiler PID espresso machine on the way"by cafeIKE on Thu Feb 14, 2008 2:18 pm
networkcrasher wrote:- Brew Boiler 1414 ml 100x180 diameter with 3 mm thickness rather then 2,5mm like most of the other boiler
That should probably be 90.5. 905mm is 35.63 INCHES
cafeIKE
Link to "Vibiemme double boiler PID espresso machine on the way"by jasonmolinari on Thu Feb 14, 2008 2:27 pm
decimal points...such a mundane detail:)
jasonmolinari
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Thu Feb 14, 2008 2:44 pm
Either way, we should hopefully find out for sure soon!
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by cafeIKE on Thu Feb 14, 2008 2:46 pm
jasonmolinari wrote:decimal points...such a mundane detail:)
You didn't by chance work on the project that plowed the probe into the Martian surface, did you? :lol:
cafeIKE
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Thu Feb 14, 2008 2:55 pm
Err, neither of those numbers look right.
would lead me to think it's a cylinder like most boilers, and at 100mm tall by a radius of 90mm (which by the way makes the cylinder really wide, but not very tall), you get a boiler that has a volume of 2.54L.
Sounds a little off...
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by jasonmolinari on Thu Feb 14, 2008 3:02 pm
cafeIKE wrote:You didn't by chance work on the project that plowed the probe into the Martian surface, did you? :lol:
no, but i did work on a project to move the decimal point pennies leftover after transactions..... (Office Space reference...the movie)
jasonmolinari
Link to "Vibiemme double boiler PID espresso machine on the way"by DigMe on Thu Feb 14, 2008 11:42 pm
jasonmolinari wrote:no, but i did work on a project to move the decimal point pennies leftover after transactions...
"Watch out for your cornhole, bud."
brad
DigMe
Link to "Vibiemme double boiler PID espresso machine on the way"by mmarxx on Fri Feb 15, 2008 1:14 am
networkcrasher wrote:Err, neither of those numbers look right.
The diameter is 90mm, the radius is 45mm. Using the basic equation for the volume of a cylinder (v=pi r^2 h), the brew boiler appears to be 1.4 liters and the steam boiler appears to be 1.1 liters. I am not sure that the measurements for the steam boiler are correct - a 1.1 liter steam boiler may be a little anemic.
Darin Marx
mmarxx
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Fri Feb 15, 2008 11:44 am
My point was speculating that the boiler is 90.5 instead of 905 would be inconsistent given the fact that the brew boiler is listed as 100x180, which leads to 2.54L. (v=pi * 90^2 * 100) -> 2.54L
I'm not sure where you get a height of 90 and a radius of 45. The only two numbers given by resellers have been 905x180 and 100x180. Were you just reverse engineering the boiler numbers from the given 1.4L?
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by cafeIKE on Fri Feb 15, 2008 2:33 pm
Quotable Quote @ Sat 05:24 pm:
"If there's one thing I've learned after many in-depth espresso machine evaluations, it's that attempting to predict espresso performance from a spec sheet is utter folly" --Dan Kehn, Commercial non-saturated, non-E61 group heads
Vibiemme has made espresso machines for 30+ years.
The Domobar Super was wrung out extensively before it reached American shores.
Let's wait and see. 8)
cafeIKE
Link to "Vibiemme double boiler PID espresso machine on the way"by mmarxx on Fri Feb 15, 2008 8:58 pm
cafeIKE wrote:Quotable Quote @ Sat 05:24 pm:
I completely agree that the quality of espresso produced by a particular machine cannot be gauged from the spec sheet alone (although, it seems that it might be possible/easier to form an opinion of a particular machine's steaming capabilities based solely on specs such as boiler size, heating element, etc. . . ). However, one should be able to calculate the size of the steam boiler based upon the measurements listed by Stefano - and that was the question to which I was responding. Networkcrasher was calculating the volume of the boiler based upon the diameter of 90mm (which is fine if the resulting product is divided by 4). Otherwise, the radius would be 45mm, not 90mm.
I notice you are not too far away in Woodland Hills - have you found any decent local roasters, or is it all mail order or trips to LA? I have not found much in Ventura or Santa Barbara Counties.
Darin
Darin Marx
mmarxx
Link to "Vibiemme double boiler PID espresso machine on the way"by cafeIKE on Fri Feb 15, 2008 9:34 pm
mmarxx wrote:I notice you are not too far away in Woodland Hills - have you found any decent local roasters, or is it all mail order or trips to LA? I have not found much in Ventura or Santa Barbara Counties.
I've found nothing in SB or Ventura, but in The Supreme Bean is in North Hollywood. In SoCal it's usually next day delivery with Ground shipping.
Out in the West Valley, Rocky Roaster on Canoga at Sherman Way is great.
cafeIKE
Link to "Vibiemme double boiler PID espresso machine on the way"by qha000 on Tue Mar 04, 2008 12:49 am
Are the DB PID VBM's out yet? I saw a couple of videos on the internet.
qha000
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Tue Mar 04, 2008 1:47 am
Should be on their way to the State from what I hear. Could you point me to the videos you've seen to satisfy my curiosity? :-)
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by Fore on Wed Mar 05, 2008 12:13 am
Fore
Link to "Vibiemme double boiler PID espresso machine on the way"by networkcrasher on Wed Mar 05, 2008 12:27 am
Dang, I thought when he said "couple" he meant more than one. I've checked out that one, was just hoping there were more :D
networkcrasher
Link to "Vibiemme double boiler PID espresso machine on the way"by jasonmolinari on Sun Mar 09, 2008 12:39 pm
Dan, any update on your review of the DB PID VBM machine?
thanks
jasonmolinari
PreviousNext
Return to Marketplace
