Bex wrote:CafeIKE: your instructions refer to installing a Manual Overfill Switch to prevent the boiler from filling during the descale process. I do not know whether that is something I can do. Your instructions suggest that switch simplifies the process - is there a more complex version that doesn't involve messing around with the innards of the machine?
Simply draw enough water from the water tap until the boiler refill kicks in. That will refill to the tippy-top and prevent an inopportune boiler refill while descaling the HX.
For the record, even if you did accidentally draw (citric acid) descaler into the steam boiler, it's no big deal. You would simply flush down the boiler a couple times as if you were descaling the steam boiler. Remember citric acid is consumable, so it's only a matter of rinsing out its sour taste.
