Spencer wrote:I've been running the Bricc (direct plumb, lever) and a Cimballi Jr. grinder on a 20 amp circuit that runs more than just the grinder and Bricc and haven't had a problem.
Good luck.
If you want to wait a week or so my Bric' will be here so you could check out in person, across the river in Vancouver WA.
Yeah, I know. The power requirements of the Bric' was the primary thing that delayed me accepting Chris's offer for a full day! Unfortunately moving the Nuker to another circuit is not an option. (SO factor and kitchen layout) And placement of the Bric' is pretty much set in stone on the counter right side of the sink. Temporarily I'll likely run a short heavy gauge ext cord from the left side of the sink outlets (which are on the kitchen's other 20A circuit) to the Bric' until I have a new dedicated circuit run, easier than remembering to turn off Bric' before using Nuker (Pretty much guarantee Debi wouldn't remember and would not be happy.) Don't use the Nuker a lot but enough for re-heating or cooking frozen veggies would kill WAF. Though left circuit may pose a different power problem, haven't checked the fridge's pull and occasionally used toaster oven... Real solution of course dedicated circuit.malachi wrote:Ummm... Mike... you might want to take the Microwave off that circuit.
Seriously.
Chris made me an offer I coudn't refuseBalthazar_B wrote:Wow, Mike, now I'm really glad I ordered the Vetrano.
As real as overloading any circuit regardless what appliances doing the overloading! 1st-Line lists the Bric' as 1900w 110v which would suck up 17.27A when fully engaged. Doesn't leave a lot of head room on a 20A circuit. Depending of the strength of the breaker sure can go slightly over for varying brief time periods.malachi wrote:Out of curiosity... how real are these perceived power issues with the Bricoletta? Has anyone actually run into trouble?
Sure, sounds great. Playing with the S1 can't be as bad on the psyche as playing with the proto LM GS3!anim57 wrote:I'll let you try out my S1 if you let me try out your Bricc
Andy
Apologies, no intention of calling you a dunce! Actual experiences would be good to know, I'll know soon enough. (well, not soon enough or I'd already have the Bric'malachi wrote:I know the theory - I'm just wondering it this has actually happened to anyone.
Grant wrote:Though I ran a dedicated 20A circuit just for my Bric (the location made it easy), I have never actually measured the draw, but you have me curious now. I have a friend with a clamp ammeter, so I will test it out ASAP and let ya know....
matt wrote:The other differences between the two (vacuum breaker, brew manometer) are no big deal, as I have the spare parts for those around already. The power difference, though -- hard to get around that.
Balthazar_B wrote:There are more differences than that, which Chris (who used to sell the Bricc) will talk about at length if you let him. I haven't received mine yet, but the Vetrano appears to be a better thought-out (i.e., engineered) machine in the same class as the Bricc (size, capacity, method, etc.). I should know within a few weeks, when I've had the chance to learn the Vetrano and, I hope, do some first-hand comparisons with the Bricc.
matt wrote:It is a sad irony that the doubtless tempting review that Dan will be starting over the weekend will start after the Vetranos are all sold out until February. Cruel!
HB wrote:If it helps, read the Buyer's Guide to the Andreja Premium. I just finished installing the Vetrano and it appears to share many of the same parts and construction of its sister (no surprise there). The rotary pump is very quiet.
malachi wrote: * The poor design of the stock portafilter may be a problem, albeit one that is easy to remedy
* The drip tray doesn't extend far enough forward which results in moderate mess when cleaning the group using the "portafilter wiggle" technique
* Its pressurestat is a cheap one with average performance, though there is more than enough room to swap in a commercial Sirai if you want to. This is something I would do given my comfort with the Sirai unit
* The orientation of the pump requires that you remove the entire casing for pressure adjustments; it should be oriented to allow for adjustments by simply removing the top. For that matter, it would be even better were the pump moved outboard
* The Bricoletta has no pressure gauge, which would be really, really helpful. Frankly, the idea of a machine of this quality and with a rotary pump that doesn't have a pressure gauge is a bit confusing to me. It couldn't possibly add that much to the cost of the machine and would make life a lot easier for the baristas using the Bricoletta
* It would be nice if the steam wand had more articulation. The stock steam tip is only average
* And, of course, life would get a lot easier if the machine (or at least the boiler) were insulated.
