Vetrano, set-up advice
Link to "Vetrano, set-up advice"by Fr. John on Tue Jun 13, 2006 10:27 am
Just about to order a Vetrano. Instead of wasting time once it gets here I'd like to be ready. My first concern is brew and boiler pressures. Should I consider tweaking these or are they fine from the factory?
Fr. John
Fr. John
Link to "Vetrano, set-up advice"by HB on Tue Jun 13, 2006 12:04 pm
They are tested at the factory and retested by Chris' Coffee. The boiler pressure will need no adjustment, but because the brew pressure of a rotary espresso machine is dependent on inlet pressure, the pump may need some minor tweaking. It comes with setup instructions that will get you started; Chris' Coffee Service FAQs also documents How to adjust rotary pump pressure and it's been discussed in the forums too: Brew pressure adjustment on Quickmill Vetrano.
BTW, thanks to Bob Craig's reminder, I've changed the defaults for HB's search to more intuitive settings that are more consistent with other search engines (specifically "and" for terms, "posts" as the result type, and a longer text excerpt).
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Link to "Vetrano, set-up advice"by Fr. John on Tue Jun 13, 2006 12:08 pm
As usual, thanks Dan. You are always helpful.
Fr. John
Fr. John
Return to Espresso Machines
