Versalab M3 Grinder - Page 7
Behind the scenes of the site's upcoming equipment reviews.
Link to "Versalab M3 Grinder"by AndyS on Sun Sep 25, 2005 9:08 am
mathias wrote:Any chance of photos of the motor? According to Versalab's homepage the grinder requires 1A, 120V. Does that mean it draws less than 120W?
What is the rpm of the motor? If not specified could someone measure the two wheel diameters?
http://tinyurl.com/dvgsq
-AndyS
AndyS
Link to "Versalab M3 Grinder"by Teme on Sun Sep 25, 2005 5:45 pm
Abe Carmeli wrote:Here the Mazzer is faster and more convenient. It takes ~ 20 seconds to grind for a shot. The Mazzer will grind enough coffee for 2 shots at that time frame, and you don't need to attend to it as it grinds.
Thank you for the summary Abe. I assume that the 20 seconds is for a double shot (as it was noted earlier on in the thread)?
By the way, any views regarding the quality of the components, the finish of the grinder and potential durability?
Also, what size are the burrs?
Br,
Teme
Teme
Link to "Versalab M3 Grinder"by another_jim on Sun Sep 25, 2005 8:18 pm
The flat burr is 64mm, iirc, don't know about the conical one. The flat burr size is deceptive. Because the conical burr does the rough bean breaking, the coarse grinding surface is a lot larger compared to the similar size Cimbali Cadet or Mazzer Jolly burrs -- see my previous posts on the topic.
The grinder section is massively solid, but so are those of commercial grinders. My take is that there is more metal on the mounts and better mounts on the drive shaft; whether this makes a difference I don't know.
Andy published a link to the Bodine DC motor used on the unit. Going DC involves the addition of a rectifier board, but allows one to set the motor speed on a pot. Bodine motors have a very good reputation, so I doubt there will be any problem in that regard. The only thought I have is this: Generally grinders this size use 350 to 450 watt AC motors rather than 110 watt dc motors. DC motors have greater torque, but my guess is that operating this grinder at higher speeds will be difficult -- the motor is sized for low speed grinding only.
another_jim
Link to "Versalab M3 Grinder"by AndyS on Sun Sep 25, 2005 8:24 pm
another_jim wrote: Going DC involves the addition of a rectifier board, but allows one to set the motor speed on a pot. Bodine motors have a very good reputation, so I doubt there will be any problem in that regard. The only thought I have is this: Generally grinders this size use 350 to 450 watt AC motors rather than 110 watt dc motors. DC motors have greater torque, but my guess is that operating this grinder at higher speeds will be difficult -- the motor is sized for low speed grinding only.
And, John Bicht from Versa is of the opinion that speeding up the grinder has a negative effect on the flavor of the resulting espresso.
-AndyS
AndyS
Link to "Versalab M3 Grinder"by Abe Carmeli on Sun Sep 25, 2005 8:54 pm
AndyS wrote:And, John Bicht from Versa is of the opinion that speeding up the grinder has a negative effect on the flavor of the resulting espresso.
I concluded a week of working with the grinder at a lower speed (I guestimate it to be around 300-350 rpm, but I have no way to tell.) I could not detect any advantage in the cup when compared with the standard speed of 500 rpm.
Abe Carmeli
Abe Carmeli
Link to "Versalab M3 Grinder"by AndyS on Mon Sep 26, 2005 7:42 pm
another_jim wrote:The flat burr is 64mm, iirc
The famous Angelo Minicozzi from Espresso Parts Source asked me to post that the flat burrs are actually 68mm OD.
-AndyS
AndyS
Link to "Versalab M3 Grinder"by luthier on Wed Oct 05, 2005 3:33 am
My new static-cling grinding scale.
You've been perfecting your technique for a long time...... So have I.
luthier
Link to "Versalab M3 Grinder"by Abe Carmeli on Mon Nov 14, 2005 5:03 pm
luthier wrote:My new static-cling grinding scale.
Nice setup, but how did you fix it in place? My concern would be that if the scale is only clinging and not really fixed to the dial it will shift in position.
Abe Carmeli
Abe Carmeli
Link to "Versalab M3 Grinder"by luthier on Wed Nov 16, 2005 5:04 am
After polishing the contact surface with metal polish, the static force and the friction will do the job well.
It won't shift at all.
luthier
Link to "Versalab M3 Grinder"by AndyS on Wed Nov 16, 2005 7:18 am
I'd humbly suggest that you redo your scale so that it has 100 graduations for one full turn. Then we all have the scale, with a common frame of reference for comparison.
-AndyS
AndyS
Link to "Versalab M3 Grinder"by luthier on Thu Nov 17, 2005 10:10 pm
Half a turn is enough for my usage.(from espresso to drip)
It has about 110 graduations(110mm, or 11cm) for half a turn. Btw, I drew this scale in autoCAD.
luthier
Beautiful burrs . . . with big holes.
Link to "Versalab M3 Grinder"by hbuchtel on Sat Feb 04, 2006 2:35 am
It seems to be an industry standard to sink the screw holes right in the middle of the flat burrs' grinding surfaces, but given John Bicht's contrary nature I'm a bit surprised he didn't find a new way to do this.
Anybody know his opinion about this?
Henry
LMWDP #53
hbuchtel
Link to "Versalab M3 Grinder"by hbuchtel on Thu Feb 09, 2006 1:15 am
hbuchtel wrote:It seems to be an industry standard to sink the screw holes right in the middle of the flat burrs' grinding surfaces, but given John Bicht's contrary nature I'm a bit surprised he didn't find a new way to do this.
John very kindly replied to an email about this question-
He said they did not experiment with this, but that compared to the benefit of other modifications changing the placement of the screw holes would not be worth the cost of having burr sets custom made.
Henry
hbuchtel
Link to "Versalab M3 Grinder"by timo888 on Mon Mar 20, 2006 12:18 pm
luthier wrote:My millennium europiccola has 51~51.5mm baskets and it's probably the smallest suitable basket size for the M3 grinder.
It's been a while since the Versalab M3 grinder was discussed on HB, but since I only recently joined up, I hope it's not too late to leave a few comments and ask a couple of questions.
I admire the machine's clean lines and simplicity very much, and trust the experts on this forum who give it high marks for distribution of coffee in the basket and for other features that lead to good espresso. But the M3 grinder seems less than excellent in terms of its user-friendliness and practicality in real-world settings, as others have already noted.
Given the variability in basket sizes, it would be a customer-friendly touch and at the same time an homage to earlier machine designers if the ring at the bottom of the funnel were easily interchangeable with rings in different sizes (i.e. varying inner diameter to accommodate different filter baskets, 49mm, 51mm, etc).
If you're going to be changing grind according to the coffee of the moment, you need some frame of reference to help you dial in the location of a desired setting. I gather it's costly to engrave the face of a cone. But would it be less costly to put the markings on the top rim of the funnel? Is that a flat surface? Arabic numerals or, to honor the Italian heritage of espresso, perhaps early Etruscan/Italic glyphs ... any set of symbols with a few dots between them would do :)
http://www.travelphrases.info/gal...nts_OldItalic.html
timo888
Link to "Versalab M3 Grinder"by hperry on Mon Mar 20, 2006 1:16 pm
I am not sure what "real world" means. The real "commercial world" or the real "home world?" Dr. Jim, who frequents these forums has pointed out to me that the design goals for a home machine should differ substantially from the design goals for a commercial machine. Indeed, many of the obstacles that we have to overcome, such as maintaining stable heat in an HX machine, are considerably reduced in a commercial shop where continuous shots are being pulled. At home, with lower usage, we're forced to "water dance and count down" in a way that would be less necessary if the machine was used commercially. It's logical enough - the machine was designed for use in a high production environment, not necessarily optimized for "the best cup of coffee possible" regardless.
I view my Versalab the same way. It's not fast enough to work in a high production environment. But it's plenty fast for the three or four double espressos I pull every morning. And it is in a whole other category in terms of grinding and distributing from the Macap that preceded it. Issues like "clumping" and getting rid of residual grounds go away.
Given the variability in basket sizes, it would be a customer-friendly touch and at the same time an homage to earlier machine designers if the ring at the bottom of the funnel were easily interchangeable with rings in different sizes (i.e. varying inner diameter to accommodate different filter baskets, 49mm, 51mm, etc.
I have successfully filled everything from a 49MM (Olympia) to a 58MM portafilter without incident. The machine maintains its excellent distribution no matter the size - its simply a matter of holding the portafilter up to the ring until the very end. As a matter of practice it isn't a problem.
Here I agree with you. My pencil marks definitely don't do the same thing as a scale would. :? The shape of the funnels makes a scale difficult to implement. I may have a skilled machinist do it someday. But if I have to choose grind and distribution over marks - I'll gladly use the pencil.
Hal Perry
hperry
Link to "Versalab M3 Grinder"by timo888 on Mon Mar 20, 2006 3:40 pm
hperry said:
[The M3 is] not fast enough to work in a high production environment. But it's plenty fast for the three or four double espressos I pull every morning.
I didn't say anything about the M3's grinding speed when I mentioned that there I had some practical "real world" reservations. That there's no hopper makes it clear that the M3 's not intended for commercial settings. Speed is not among the important criteria for home-grinders. I think we're in agreement on this point too.
SCALE
Since you mention speed, I'd say that John Bicht's exposed-wheel race-car test-driver background is revealing itself in the M3's design. You have to drive the M3 by 'the seat of your pants' and that's part of the appeal, I think, for the designer; he's trying to give the user a sense of that raw machine joy. I do appreciate that aesthetic but believe a compromise respecting the needs of the user would not detract from the machine's essential appeal and would remain true to its intended purpose. The aesthetic challenge is to come up with grind scale markings that are suited to the machine. An improved machine would let one quickly return to a previous successful grind setting for a bean enjoyed a few weeks ago ... avoiding a lot of grind-bracketing.
49mm PORTAFILTER
With regard to the other limitation I mentioned, the small portafilter issue, I was quoting from luthier who remarked that 51mm is the smallest basket he'd recommend for the M3. I didn't see anyone taking issue with his statement. I am happy to learn that you've had no trouble with your 49mm Olympia baskets. Grinds aren't sprayed out through the space between the basket and the ring?
EXPOSED BELT?
Finally, having to clean the belt weekly with alcohol to prevent slipping struck me as another feature that was less than ideal. Would the need to do this belt servicing increase in frequency the older the belt gets? Was there ever an answer provided about the belt's expected lifetime? In the photographs, the belt looks exposed. Is that so, or is there a lid that was removed to showcase the mechanism? If the former, is there a danger that something could become snagged in this exposed belt assembly as it spins? Isadora Duncan's scarf, perhaps, or my wife's long hair?
Regards
Timo
timo888
Link to "Versalab M3 Grinder"by hperry on Mon Mar 20, 2006 5:17 pm
SCALE
Totally agree. John Bicht has argued that it would materially increase the cost of the device and appears to not have an investment in doing it.
49mm PORTAFILTER
As long as the portafiler is held against the ring there is no spray. I drop it down to pick up the last grounds from the funnel and that will cause some spillover.
EXPOSED BELT?
Belt maintenance is required with some regularity, although they are providing a new belt which reduces the need to do so. It's also somewhat coffee-dependent. I use some beans that have a light oily sheen. When using them there is not much belt cleaning. Beans that are not oily require more frequent cleaning of the belt. The cleaning requirement is reduced considerably by following their new procedure, which is to add the beans after starting the grinder. It may be a "cost of doing business" to meet other design goals that he has.
The belt is exposed. There are very tight tolerances between it and the side guard making it difficult, but not impossible, to get something in there. From a safety standpoint, objectively speaking, it should be covered. I do like the aesthetic the way that it is and think that adults, using common sense precautions, should not get into trouble.
Hal Perry
hperry
Link to "Versalab M3 Grinder"by timo888 on Thu Mar 23, 2006 9:48 am
Perhaps if the top metal plate were extended by a few millimeters, a plexiglass cap could be bolted to the top plate, protecting the belt from coffee dust and thereby reducing the maintenance while improving safety, yet leaving the mechanism exposed to view. A plexiglass tray could also be inserted into a tray-holder on the base. The tray could have a cylindrical cutout to permit insertion of filter basket below the funnel. The hole would be 58mm in diameter with brass ring inserts to bring the diameter down to 49mm. A tight-fitting plexiglass cap with detents could also sit on top of the upper funnel.
Timo
timo888
Link to "Versalab M3 Grinder"by hperry on Thu Mar 23, 2006 11:02 am
The top cover could work, although it would compromise the aesthetic. There is also the inevitable scratching that plexiglass would bring. As a practical matter, though, the weekly belt maintenance takes far less time that the almost daily "brushing out" of machines to get rid of old coffee which many users of other grinders report. Never have to do that with the Versalab.
I don't really see the need for the tray as I easily move from 58mm to 49mm going from the Olympia to the Termozona. At 49mm grinds don't spray if you hold the portafilter to the ring. It would introduce a level of complexity into what seems to me to be an elegant and simple solution as it sits.
Hal Perry
hperry
Link to "Versalab M3 Grinder"by timo888 on Thu Mar 23, 2006 11:37 am
There must be some shatterproof, scratch-resistant, moldable glass-like substance that would glisten and complement the machine's aesthetic, to cover the exposed belt.
A filterbasket-holding tray could be an optional feature for those of us too lazy or too distracted to stand in front of the grinder holding a PF.
As for the flexible collar with detents that fits around the lip of the top funnel... that could be an easy retrofit if the collar were split and had spring-tension like the piston ring on the new Cremina that Steve Robinson wrote about in his piece about the evolution of a design. Instead of numbers, the collar could use glyphs taken from various alphabets around the world, wherever coffee is grown. If there were a reference dot on the funnel to ensure that Versalab owners could synchronize their collars, people could then communicate their successes so:
Godshot with this Ethiopian with the collar set two detents to the left of
Regards
Timo
timo888
PreviousNext
Return to The Bench
