another_jim wrote:The Ascaso grinders use the Trespade burr set, same as the Lux, the Pavoni PG, and the old Innovas. This burr set produces a grind quality at least as good as small commercial grinders like the Mazzer Mini. The drawback is that it is very noisy.
Agree. I have Gran Macinino, which I think is the same burr set. We call it the Gran
Banshee. It does grind well for espresso, it's just not very adjustable.
another_jim wrote:I have not tried the new Baratza, which addresses many of the problems of the older Maestro models.
Tried two Baratza Virtuosi. Way too much
static. The scale is far too large. Only about 5% is useful for espresso, which is not much use at all. Baratza is a great company with customer service second to none.
another_jim wrote:Not having the "exactly" right grind setting is way overrated as a problem, IMO. A few seconds more or less, a few grams more or less, is not going to make the least bit of difference to the way the shot tastes, provided you stop it at the right color.
If the exact right grind is not a must for good espresso, it's a luxury I'd never give up. It's a valuable tool to use in conjunction with dosing level and temperature when extracting the nth degree from a coffee.
another_jim wrote:Grinders do vary dramatically in how easily they pack, and doserless models are usually not as good as doser ones, where the thwackety-thwack eliminates clumps. This is ultimately an issue of barista technique, not grinder design, but the easy life is always nice. I'm guessing the Virtuoso may have problems in this area, judging by the complaining newbies; the Trespade grinders are harder to pack than commercial doser models, but manageable.
IMO, dosers are for barista wannabe's. Both my Macap and Gran Macinino clump far less than doser Mazzer Mini's I've used, with the same coffee. Marshall will say it's inelegant, but I use a cut down yogurt cup to load the PF, then give a gentle side to side shake to distribute. Grind fine and don't over dose.
The 2p : Ascaso iMini.
