The Ultimate Home Roaster Project
Link to "The Ultimate Home Roaster Project"by keno on Sun Apr 01, 2007 12:25 am
Espresso enthusiasts have long sought to enhance their experience through home roasting. Some are content to rely on inexpensive mass produced home roasters like the i-Roast, Gene Cafe, Alpenroast, and Hottop. But in the quest to perfect the home roast the true aficionado's have continually pushed the envelope of home roasting equipment. Techies make PID controlled popcorn poppers, artisans roast by hand over the stove top, Nascar fans use heat guns and dog food bowls, while the manly-men use gas grill drum roasters.
But the problem is that all of these home roasting devices have serious flaws. Most roast batches that are far too small, lack adequate precision over roast profiles, are difficult to use, and cannot match the quality of a true commerical roast.
So, I decided to push the envelope even further in my quest to go where no home roaster has gone before. Surely, I thought, there must be some untapped home appliance that can be converted into the ultimate home roaster for those of us who cannot afford a $15,000 Diedrich commercial roaster.
Then one day, while observing my wife doing the laundry, I had an epiphany - the household dryer! The many advantages of converting a dryer to a home roaster were suddenly obvious to my espresso infused brain: (1) virtually every household has one, (2) due to the drum design it should have the refined roast profile of a drum roaster, (3) it is large enough to roast a substantial amount of beans, (4) it is already set up with external venting, and (5) it has excellent built-in user controls. Having never used my wife's dryer before I quickly got to work on modding it.
My wife's clothes dryer
After a few quick modifications I had created the MEGA ROAST 4000! This baby is capable of roasting up to 4 pounds of coffee at a time and as you can see it has complete functionality for selecting your preferred roast.
The MEGA ROAST 4000! 22,000 BTUs of roasting power!
Here are some green beans loaded into the MEGA ROAST 4000 and ready to go.
Ready to roast a small test batch of Brazilian, Ethiopian, and Sumatran
My first few roasts were promising, but far from perfect. I realized that it would take some experimentation to dial in my new home roaster. To help dial in the machine and develop the ideal roast profile I hooked up my thermcouple to the MEGA ROAST 4000.
The MEGA ROAST 4000 on its way up to the target roast temperature of 400 degrees
Here is a pic of a full city roast that took 15:30.
Look at that nice even roast and imagine being able to roast 4 pounds at a time!
Make sure to clean the built-in chaf collector after each roast!
The quality of the pours from the MEGA ROAST 4000 far surpass anything I've ever had - I got wonderful sweet chocolate honey with floral overtones from this blend of dry processed Brazilian, Ethiopian Harrar, and Sumatra Mandheling.
As my friend Borat Sagdiyev says: "She's nice!"
My model is based on a gas dryer and I'd recommend a gas dryer over an electric - I think it's got better and more even heating. If you try it with your electric dryer please post to let everyone know how it goes.
Despite all the clear advantages of using a dryer as a coffee roaster, there are a few disadvantages (but nothing that can't be overcome with a little ingenuity).
(1) When roasting larger quantities of coffee you need to be EXTREMELY CAREFUL not to roast too dark - otherwise you could start a huge fire in your laundry area. So either make sure you have a fire extinguisher or keep the washer fully loaded with water and have a bucket handy.
(2) The amount of smoke can get quite overwhelming despite the external ventilation, so be prepared to set off your smoke detector (but DO NOT DISABLE). The smoke can also make your laundry smell like coffee (my wife got quite upset about this, but I think it's a plus - in fact I'm now thinking about developing a coffee scented laundry soap).
(3) You have to roast by smell and sound, if you open the door to check the beans you'll stop the roast and reduce the temperature. Next weekend I'm planning to cut a hole in the door to add a window - problem solved!
(4) Cooling the beans is challenging, especially for large roasts. My next project, after the window, will be to work on converting the washing machine to run a cooling cycle. I'm thinking I could mount an air conditioner on the side of the washer which would run on spin cycle (with the water disabled of course).
(5) WARNING - This device can be dangerous to your marriage! If your wife thought you were crazy spending over a grand on an espresso machine and she freaked out when you bought a $500 grinder, then she may leave you when she sees you've commandeered her clothes dryer to roast coffee.
This is the ultimate home roaster and I challenge anyone on HB to produce a better, more versatile home roaster, using an ordinary home appliance. I know you probably can't wait to get your hands on on one of these. Not to worry, shortly I will have kits available to convert your dryer to a home roaster. The kits are expected to retail for $295 - far less than a Hottop and far better! I'm taking pre-orders now for the special introductory price of $195 for HB members only, so place your order right away because these will sell fast.
:wink:
keno
Link to "The Ultimate Home Roaster Project"by TimEggers on Sun Apr 01, 2007 1:09 am
:shock:
Wow.
What do I say to something like that? Man that's cool.
You don't actually dry clothes in there afterwards do you?
Tim
Espresso Padawan
LMWDP #202
TimEggers
Link to "The Ultimate Home Roaster Project"by another_jim on Sun Apr 01, 2007 3:00 am
Nice work. But you forgot to mention that for espresso roasts, it's very useful to add a fabric softener sheet. This extends the "glass phase" of the roast just after the first crack, and creates a slightly softer bean. This in turn allows for finer grinding and improved extraction.
It also would help to post instructions on how to cool the beans. Does your kit work in conjunction with the permanent press cycle to do the cooling internally, or do the beans have to be removed and cooled externally?
another_jim
Link to "The Ultimate Home Roaster Project"by DaveC on Sun Apr 01, 2007 7:12 am
Sorry guys but I'm still loyal to the Aromaroast
http://myweb.tiscali.co.uk/coffeetime/_sgg/m4m1s9_1.htm
and of course all those other wonderful products for April!
DaveC
Link to "The Ultimate Home Roaster Project"by Rainman on Sun Apr 01, 2007 8:09 am
Ken- you're up 'till 1:25 AM doing this stuff?
hey, where'd your signature go- you know the one; if not for coffee, etc....
pretty funny- almost had me going to the laundry room myself!
LMWDP #18
Rainman
Link to "The Ultimate Home Roaster Project"by fredfal on Sun Apr 01, 2007 9:45 am
I almost spit coffee all over my computer.
-Fred
fredfal
Link to "The Ultimate Home Roaster Project"by Spresso_Bean on Sun Apr 01, 2007 10:52 am
Oh man, that is awesome. I love the dial settings. LOL.
Spresso_Bean
Link to "The Ultimate Home Roaster Project"by TomP10 on Sun Apr 01, 2007 11:49 am
Let's give credit where credit is due... the world's greatest coffee roaster -- Mr Sidd Finch -- was the first person to use a dryer as a coffee roaster --- back in 1985 if my memory serves.
- Tom
TomP10
Link to "The Ultimate Home Roaster Project"by hgs on Sun Apr 01, 2007 12:47 pm
why risk problems with the wife, the hassles of cutting a hole for a window, and my horizontally-challenged lint-screen that won't catch the chaff? i took your advice, but will only be using the machines at the laundromat on the corner. for $1 of qtrs, i can use a heavy-duty machine with a pre-installed window for constant viewing. no problems with my significant other (we use our own machine for clothing) - so i won't have to worry about coffee-smelling clothing. i will only go late at night so i don't get hassled by the regulars there. thanks for the great home-roasting solution - and sorry, i won't be needing the conversion kit.
hgs
Link to "The Ultimate Home Roaster Project"by cannonfodder on Sun Apr 01, 2007 8:13 pm
I built a one pound roaster from a rotisserie toaster oven. I had to make a stainless steel drum, weld the rotisserie rod mounts to the drum, fabricate a hinged lid to charge and dump the drum. The roaster did not get hot enough so I pulled the case off and insulated the oven chamber with high temperature ceramic insulation and added an electric charcoal starter in the bottom to augment the lower heating elements, there is an upper broiler set as well.
The oven would now spike my 600F oven thermometer, which I mounted in the back of the oven. I can control the upper burners, lower burners, both sets and the lower auxiliary burner. I also have temperature control. The little rotisserie motor finally gave out after a year of use so I got and external motor with a reduction gear and wired it in on the outside of the oven case. I then welded together an extension to bridge the gap between the external motor and the internal rotisserie mount.
It worked quite well, but eventually I got a Hottop and relegated my homemade roaster to backup duty. The Hottop is just easier to use.
I will have to look for a photo and post it.
Almost forgot, for a cooler, I dumped the beans into a large wire mesh colander and used my air compressor with the regulator turned down to around 20psi and blew air up through the beans. That cooled them very quickly and blew out any remaining chaff.
cannonfodder
Link to "The Ultimate Home Roaster Project"by TomP10 on Sun Apr 01, 2007 8:26 pm
Ummm, perhaps folks might want to read this post before making further suggestions for modifications to this fabulous roaster. I think it pretty much explains everything!
TomP10
Link to "The Ultimate Home Roaster Project"by Adrock on Sun Apr 01, 2007 11:02 pm
I suppose you could assemble an air roaster with a hair dryer and a bowl or funnel of some sort, but your idea is both more entertaining and more effective.
Adrock
Link to "The Ultimate Home Roaster Project"by keno on Sun Apr 01, 2007 11:26 pm
TomP10 wrote:Let's give credit where credit is due... the world's greatest coffee roaster -- Mr Sidd Finch -- was the first person to use a dryer as a coffee roaster --- back in 1985 if my memory serves.
- Tom
If memory serves correctly Sidd Finch was one hell of a rookie pitcher for the NY Mets who was reported to throw a 165 mph fastball! I didn't realize that he made home roasters too. Wow, very cool! I'd love to meet him someday. Does anyone know if he's still alive?
If not for coffee, I'd have no personality at all.
keno
Link to "The Ultimate Home Roaster Project"by hgs on Mon Apr 02, 2007 11:04 am
did anyone catch the WSJ article about miracle fruit on friday? i had to go back a few times to determine it was legit... i'm still wondering if this is some remnant of an old story from an april past that has gained a life of it's own...
http://en.wikipedia.org/wiki/Miracle_fruit
has me thinking what an espresso shot would taste like after eating the fruit :?
hgs
Link to "The Ultimate Home Roaster Project"by Gregg K on Wed Jul 02, 2008 10:46 pm
Oh my god! This is totally brilliant!
I don't care if this thread is old, I have to reply with glee.
I've been so sad. I lost my beloved cat, Farnsworth. But this has brought some sunshine into my life.
I'd love to know if this is for real. I'm a skeptic. Please let this be an honest endeavor. Because I'm going to be wearing espresso flavored jeans, if it's true. My old dryer is sitting there waiting to be revived.
Gregg K
Link to "The Ultimate Home Roaster Project"by Spresso_Bean on Wed Jul 02, 2008 11:02 pm
Gregg K wrote:I've been so sad. I lost my beloved cat, Farnsworth.
Sorry to hear about your cat - that's something I've always had a tough time with. RIP Farnsworth :cry:
I don't think the dryer roaster is real, but it was so funny to see. I bet someone could roast in a dryer if they could get the heat up high enough, and then just add a temperature probe and trier lol.
LMWDP #200
Spresso_Bean
Link to "The Ultimate Home Roaster Project"by Gregg K on Wed Jul 02, 2008 11:33 pm
Thanks. He was a great cat. 22 pounds. We went on a long journey together.
I thought the temp of a dryer wouldn't be sufficient. But it's a great thought.Image
Gregg K
Link to "The Ultimate Home Roaster Project"by HB on Wed Jul 02, 2008 11:58 pm
Gregg K wrote:I'd love to know if this is for real.
Please note the date of the original post: April 1st, 2007. I hurt myself laughing the first time I read it. Sorry to hear about your cat, I know how it feels; I wrote Toonces and our morning routine over three years ago and still miss my espresso buddy.
Link to "The Ultimate Home Roaster Project"by Gregg K on Thu Jul 03, 2008 12:26 am
Oh Dan, thank you. That was wonderful.
He was born under an oak tree with, I kid you not, a twelve foot diameter. I was there. His mother toted them one by one under my cabin in the woods. And even before that, when I had just moved in a year before, on a stormy night, there was a knock on the door, and it was her. She was feral and didn't want to stay. But was saying that she existed.
I lost his brother, Bart, a year ago. Bart evolved to the point where when I so much as turned on the Mazzer, he knew the milk wasn't far away. I would turn on the grinder and look over at the couch, and he'd give me that affirming look of understanding. Man, I miss that.
Well, so as to keep this somewhat off topic, and not totally cat related, I ordered one of the last Reneka Techno's in existance from Boyd. It should be here in a couple of days. Yee haw.
Now if I can only repair my soul.
Gregg K
Link to "The Ultimate Home Roaster Project"by Psyd on Sat Dec 20, 2008 11:24 pm
Gregg K wrote:Now if I can only repair my soul.
I've lost Decibelle the Sound dog, Sage Underfoot, Lace, and Whisky in the past decade. Trust me, the best way to repair your soul is to adopt another. If you think you might like dogs, but you're pretty sure you love cats, may I suggest a greyhound. Mostly cat, but with all the great attributes of a dog, too.
I just had both dogs undergo major surgery. $14K. I gotta guess that the new kids have already stolen my heart... and saved my soul.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Return to Home Roasting
