by jamiedolan on Tue Jun 10, 2008 8:12 am
Goodmorning;
Thank you again to everyone that has so kindly assisted with my recent questions. A couple updates for you. I have a Ariete Espresso machine that comes with a pressurized portafilter basket, 53mm. I was unable to find anyone that sold a standard portafilter for this size. This was frustrating, and a bit disappointing. My current portafilter basket has all the holes in it on the inside of the basket, just like a standard commercial basket, however, the bottom that is molded on, only had one hole on it. Since I could not find a basket, I decided to take my chances with a "mod". Off to the garage and I fired up the bench grinder. Well, it took a while, but now I have a standard commercial style portafilter basket. I ground that entire bottom plate off, but with extreme care, managed to not damage the bottom plate with all the holes in it, and I managed to get all the holes opened up. Success!
Last week my Mazzer Mini e came. I had the grind set so I was pulling about 30 second shots. Once I put the "new" commercial style basket in place, the same grind with the same amount of beans now pulled a shot in about 15 seconds. So I adjusted the grind so it was much finer, and now I am back to close to 30. I believe that I am using about 20-30 pounds of pressure for the tamp most of the time. I break up clumps and even out the top of the basket with care before tamping. I feel the shots are substantially better than any previous results I have ever achieved. I am putting 13 grams in the basket, because it is my understanding that a 53mm double shot basket should hold 13 grams. Now here are the questions I have.
1. With 13 grams in the basket, with my current grind setting, the basket is only about 2/3 to 3/4 full before tamping. Does this seem correct, or do you think I should be using more coffee?
2. I am pretty happy with the crema I am getting, but feel there is room for improvement. I am not sure what area I should focus on to tweak the crema. Any suggestions.
3. I am using Stonyfield Farms Organic Whole Milk for my milk, no matter what I do, my milk / foam always seem a bit thick to me. At the scaa competitions everyone was using organic whole milk. Should I try different milk or is it just the way I am steaming it, or possibly just because of my underpowered machine?
One last item to note; the bean of the day, that I am working with in regard to the above tests is a Costa Rican that I roasted to about a city roast in a RK drum, 2 nights ago.
Thanks Again Everyone!
Jamie
