miniman wrote:Ok! I took comments last night and adjusted the OPV, instead of pressurestat. I have just the right screwdriver (LARGE) to get at it. I gave it a 1/2 turn (clockwise) and put everything back together to use this morning. I cranked it up and tried to pull a flushing rinse through the portafilter. I could not move the lever! (Maybe a safety interlock?) I briefly pushed the microswitch and saw the manometer go to 12!
I opened the machine and turned the OPV back 1/4 turn and tried everything again. My boiler runs right near the "1" mark or slightly higher (to the tip of the green zone). Loaded a shot and initially got "4" (like I do when I put the blank in) then went up to "9" Perfect shot! Did another one for my wife and it went between "9-10" I backed the OPV off another 1/4 and will re-try tomorrow.
Moral: a little turn on the OPV makes big changes unlike the pressurestat screw.
Well, you took
some of the comments.....
Better Moral 1: make sure that the problem is with the machine before changing settings
Better Moral 2: if you are not absolutely sure what you are doing, do not adjust anything
Your assumption seemed to be that there is a problem with the machine- if that was the case then the best thing would have been to find the problem instead of making adjustments of which you were not sure. Why? if there is a problem with the OPV, then adjusting it to a higher pressure may cause damage or premature wear to the machine. (EXAMPLE: OPV sticking open causes low pressure. You adjust to a high pressure and now it sticks closed)
I am not stating that there is not a problem with the machine- there could be. Your sticking operating lever indicated that there may be a bit of something in the brewhead causing problems. BUT, a safer set of guesses as to the cause of a low indicated brew pressure are too coarse of a grind or poor distribution or tamping. Maybe even a cracked basket.
Simply finding screws to turn and fiddling with them on a $1300+ machine is generally not recommended.
The advice you received earlier was to use the blind filter and check the reading on the brew pressure gage. That is the easiest and best (and safest) way to judge whether or not the OPV is operating properly.
The advice I originally gave was to grind so fine that the machine is choked and slowly adjust the grind a little at a time to a more coarse setting to find the correct grind (and thus eliminate that as a possible cause of your problem). IIRC, you originally said that the flow was too fast and the pressure reading was too low- those two occurrences together could indicate that the OPV was set TOO HIGH, not too low.
Your original adjustment of the pressurestat, mistakenly thinking it would control brew pressure, seems to indicate that you may not have a full understanding on how the machine works. Please proceed carefully.
