Leaving espresso machine ON 24/7 vs turning it on & off 4 times a day. - Page 2
- arcus
My machine takes a long time to warm up and it's not unusual for me to have an espresso later in the evening (I have a high tolerance for caffeine) so I'm starting to think it's not worth it to use a timer. I've been leaving it on 24/7 for over a month now and I'll probably continue with that for now. I'll figure out a less important area where I can cut back to keep my carbon footprint neutral.
If they weren't, and the overheat protection circuit fails, it bye-bye coils, eh?baldheadracing wrote:Good thing that the coils are in litres of water, then!
More likely bye-bye pressure relief and if that fails too, bye-bye room. Not likely the coils will fail if there is still water in the boiler.
Ira
Ira
The coils are not likely to fail early if treated with respect but, I will say this... home water heater coils do fail and they are typically maintained in a bath of hot water 24/7. I simply stated the concern I have and why I do what I do.
But not likely because the water got too hot, more likely because of scale or corrosion.
Ira
Ira
I don't think we are on the same page, Ira. I wasn't referring to heat of the water. I was referring to metal expansion and contraction of the coils themselves by bringing them up to temp then powering them off letting them go back to ambient repeatedly everyday. Perhaps, I wasn't clear on that.
I agree that sediment buildup in the tank is a common cause for heating element failure.
I don't want to get into a last word battle so I'll leave it at that.
Charlene wrote:I don't think we are on the same page, Ira. I wasn't referring to heat of the water. I was referring to metal expansion and contraction of the coils themselves by bringing them up to temp then powering them off letting them go back to ambient repeatedly everyday. Perhaps, I wasn't clear on that.
While I'm not sure this is an issue, I'm willing to accept it might be, but that's not what I was responding to.
Ira
