ShureShot timers for La Marzocco, Synesso, Slayer etc - Page 8
I guess this could be considered "correcting factual errors", anyhoo - here goes;
sdalcorn is my personal account and my company is Alcorn Café Engineering. We designed and manufacture the ShureShot Timer.
2 Inputs (for Slayer and Synesso Levers and later our MP Head replacement)
4 programmable timers (0~99s)
3 programmable outputs - YOU tell it what you want the outputs to do at any point in the extraction
Cleaning Function
Auto Group Head Pre-Flush (0~9s)
Auto Group Head Post-Flush (0~9s)
Switch between Auto (Chronometric?) and Manual mode
It is NOT a Volumetric Controller. It does NOT provide any analogue control of pump pressure.
It's a shot timer. It was conceived as a shot timer. It is a shot timer and then we just kept adding features to to it'I won't lie - I'm still not EXACTLY sure what the Shureshot does after all of this very technical discussion (and by looking at the website), but I AM most definitely interested!
Cleaning Function
We switch 3 outputs according to time. The pressures are controlled by the particular machine and either standard or additional hardware.Is there a 'layman's terms' description of all of it's functions? As for the multi-stage pump possibility (from my understanding of the diagram), are the times and the levels of pressure adjustable?
Again - I don't think I am allowed to - but I guess we'll find out.Just some clarification might be great for folks considering a cool option for their own machine but aren't quite clear exactly what they're getting into would be great.
I thought the Marketplace was for sponsors only? I have asked about being a sponsor and am more than happy to.That being said, I believe if you put up a post in the 'Marketplace' you would be allowed to discuss your product openly (HB - please correct me if I'm wrong!). You could make the title simple (something like 'ShureShot Timers For Home Barista's) and include a simple explanation, pictures of your product, and even some videos of it in operation if you wanted to.
- AssafL
It looks like a good solution for those machines that do not have a built in timer and/or volumetric control.
Machines that stand to gain the most will be of the kind that:
1. Have an electric Brew valve (what is known as 3-way) - so manuals like levers and E61 will not have the benefit of automation.
2. Not have a built in timer.
3. Be plumbed in to enable pre-infusion.
4. Don't have a cleaning cycle.
For example, I can see this being awesome on a Mini Linea. It will add automation, pre/post-infusion, timer capabilities, a cleaning cycle and pre and post flushes.
At $170 the price is similar to other coffee related controls (such as the TC4C roaster control board with LCAdapter).
As for plumbed-in semi-automated AV machines that have built in timers and cleaning cycles (like the GS/3) - I still think this is overkill for the rather mundane task of separating the pump activation from the 3-way activation (which is all you need for pre/post-infusion). 2 caveats:
1. If you deem automated pre & post flushes are important (I happen to not think so - at least not on a saturated group) - then perhaps it is still worth your while.
2. It does take some technical dexterity to select, install and configure the necessary control to separate the motor and the 3-way valve (even on a GS/3. So there is a definite advantage for those less technically inclined.
3. You will have two timer displays. I don't like having two timers - looks like a bad design. You can turn off the GS/3 timer or hide the Sure Shot controller in the machine (so it can do its thing in the background).
Can anyone tell me how to contact Shureshot (AlcornCafe) ? I've tried the form they have on their website but have not received a response and the form doesn't allow for comments either. Any help would be appreciated.
- canuckcoffeeguy
Try through their Facebook page:
https://www.facebook.com/alcafebrewer19/
- Terranova
- Supporter ❤
You can also contact him via Instagram. We installed his Shot timers on our workshop Slayer and we really like them.cowboy80 wrote:Can anyone tell me how to contact Shureshot (AlcornCafe) ? I've tried the form they have on their website but have not received a response and the form doesn't allow for comments either. Any help would be appreciated.
- Terranova
- Supporter ❤
michael wrote:what does the shot timer add to the slayer
You must have missed Sean's answer.
Cleaning Function
Thnx
who could I get to install this in the united states in a new slayer
