Setting auto brew cycle on Pasquini Livia 90 Auto.
Needs some info on the Livia 90 Auto setup of the auto brew cycle. Does it only set the extraction time or it also set to the amount of liquid?
I have one I've been resurrecting from the dead and finally got it working. Still have some things to do but have it close enough I finally made a couple of extractions today. Then I tried the two cup auto brew, figured the previous owner already had it programmed. With no coffee in it, it ran for 25 seconds and delivered 3.5 ounces of water. I did a slightly coarse grind and tried that, it still ran exactly 25 seconds and gave a 62 gram shot.
I see the unit has a volume/flow meter on it to measure the amount of water, if it's working. Does it use that also so you can set it to only deliver a certain amount of liquid and I just need to reset the auto program to what I want, or does it just time the shot?
