Source for Olab water fill solenoid o-ring?
benjita
#1: Post by benjita »
I have a leak at the water fill solenoid/valve connection in my Quick Mill Anita. Solenoid is by Olab. The leak appears to be due to a degraded o-ring. Checked in with Chris' Coffee but they do not carry a replacement o-ring. Does anyone happen to have a source?
erics
Supporter ★
#2: Post by erics »
The seal is a Teflon gasket and I just removed the one that I had laying around. You are welcome to it (gratis) but I would prefer to install it myself.
I am at 301-587-5033, Silver Spring, MD.
Skål,
Eric S.
http://users.rcn.com/erics/
E-mail: erics at rcn dot com
benjita (original poster)
#3: Post by benjita (original poster) »
Eric, thanks for the note. I've seen a lot of your posts on the Anita. I didn't notice you were in MD. I'll definitely reach out to you for local assistance. I've gotten the solenoid off but am not sure how to identify the o-ring.
erics
Supporter ★
#4: Post by erics »
Once again (and cheerfully), it is NOT an o-ring seal but is a Teflon gasket. I removed the Teflon from an old OLAB solenoid I had laying around and, PERHAPS, this would solve your problem. In any event, this is a simple fix BUT the permanent solution is to replace the OLAB with a Parker solenoid valve which can be a little tricky.
Skål,
Eric S.
#5: Post by benjita (original poster) »
Sorry about that. I still need to get up to speed on the nomenclature!
#6: Post by benjita (original poster) »
Eric, Thanks again for being so generous with your time today. I'll report back if I'm able to track down the dimensions.
