La Pavoni Europiccola: remove plastic grouphead insert
Hi,
I am maintaining a millenium europiccola and I want to clean and remove the plastic grouphead insert. But I have not found any instructions how to remove. Is there any specific way (unscrew) or should I just try to pull it off? On the inside top there are several grooves under which I could be able to put some lever. Thanks
Picture from http://www.francescoceccarelli.eu/
- crazy4espresso
Removal of the sleeve is really only necessary when replacing it. You can sufficiently clean the group otherwise. It unscrews out and you can purchase a special tool, or improvise, as in the following thread:
La Pavoni Europiccola maintenance and bike tools
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
