Convert E61 to plumb-in: Why can't it be done? - Page 2
- erics
- Supporter ★
That's certainly true but a reduced pressure (like, say, 30 psi) would make life easier on any float valve of this type.No water line regulation needed.
If I were to do this, I would certainly get a recommendation from the particular float valve manufacturer as regards the acceptable input pressure range.
I know this question is a little old, but for what it's worth, I successfully managed to plumb in an Ulka vibration pump. Originally I was running with a float valve in the tank, but it was hard to clean an sounded like a toilet refilling!
I posted a while back when I was asking about returning the OPV, which I ended up feeding back into the reservoir with on issues. Didn't worry about plumbing in the drain since it needs cleaning every day anyway.
Modifying ECM Rocket to direct plumb-in
- pizzaman383
- Supporter ❤
I have run this way for several years.jonr wrote:With the right regulator, house water pressure can be regulated down to a very slightly negative pressure. Ie, the vibe pump will have to suck just a little bit (less than drawing from an under-counter tank). This creates a system that is less likely to flood. Priming the pump might be necessary.
One can also do some re-plumbing with a check-valve and send both house water (at say 50 psi) and vibe pump output to the boiler - which ever is higher will have precedence. Of course this loses the safety of the first option. A dimmer or variac on the vibe pump would be more flexible.
Curtis
LMWDP #551
LMWDP #551
