Advice on New Espresso Machine & Grinder, Maximum Budget $2250 - Page 3
In case anyone is interested, I also came across a Rocket Giotto Evoluzione V1 that is for sale (from what I can tell, the V2 came out several years ago). I was told that the only changes were aesthetic (new knobs and gauges), though I'd like to do a little digging to confirm.
- Fausto
Well the outer casing is just polished stainless steel. The frame does have some sort of black (maybe powder) coating on it. I've heard some people prefer like a stainless covering on the drip tray rails to prevent wear, and if you're worried about that I think a simple piece of electrical tape would work about as well (they might even be adding the stainless to newer models). The frame of all Profitecs is a single piece of metal (steel I assume), whereas some companies bolt/weld 2+ pieces together. So the frames are pretty good in that sense.mwalter wrote:Is the frame coated? I've heard complaints about coated frames on Profitecs.
Not too familiar with that machine, but I know it's pretty popular, probably for a good reason!mwalter wrote:I spoke with Diane at 1st-Line and she suggested that I consider the Bezzera BZ07.
