Ambient Room Temperature and Brew Temperature Stability
I live in an older house, my Quick Mill Alexia is on a timer and warms up an hour prior use. In winter I turn on the thermostat for the house after waking so my kitchen is probably starting out at 55-60F as I pull the first shot, and then warms up to 68 degrees within 15 minutes. Do you think the change in ambient temperature is making the brew head temps less stable? I feel like my consistency is declining.
- RapidCoffee
Less stable? Unlikely, but this is easy enough to check: compare successive shots before and after the room temperature reaches 68F.
A lower ambient temperature might result in a marginally cooler initial brewhead temperature, but a warming flush should take care of this.
I suggest you look elsewhere for consistency problems.
John
James, I know we had some discussion in the thread I started about my Alexia EVO and think you mentioned you have Eric's group thermometer. What does that show during idle and brew?James Mulryan wrote:I live in an older house, my Quick Mill Alexia is on a timer and warms up an hour prior use. In winter I turn on the thermostat for the house after waking so my kitchen is probably starting out at 55-60F as I pull the first shot, and then warms up to 68 degrees within 15 minutes. Do you think the change in ambient temperature is making the brew head temps less stable? I feel like my consistency is declining.
I confirmed with him it shoul read 3-5f above brew temp half way into the shot. As it turns out, I need a 28f display offset regardless of the stock 18f offset...and my ambient temp is 67ish..
I tested this with a homemade Thermofilter (calibrated for my location) and confirmed consistent brew temps of 200f with 204-205 readings on the group thermometer.
- erics
- Supporter ★
Yes . . . less stable to the extent that the grouphead temperature will be fully stabilized after a one hour warm-up BUT when you then modify the ambient temperature, the grouphead temperature will also rise.Do you think the change in ambient temperature is making the brew head temps less stable?
Everyone has their particular comfort zone but I would suggest you invest in a simple programmable thermostat such that you wake up to the 68 F you subsequently adjust the thermostat to.
