Quest M3 cheat sheet - Page 2
Pardon the dumb question, but the block of wood is part of your setup too, yes? And the fan is at the window-end of the ducting too? Is that something a home improvement store could more-easily do?UltramaticOrange wrote:I have experience doing this. Just don't even bother trying. Even in the milder winter weather of WA, you wouldn't be terribly happy with the results. Instead, I recommend setting up some ad-hoc ventilation by a window like the below. Just a simple 12v computer fan, an old 12v power adapter, some ridgid duct work, and an oxford comma.
Just held in place by shutting the window, and then I would pull it out of the window when I was done roasting.
<img>
- SAS
- Supporter ❤
Here is what I did to vent exhaust on the Quest.
The flex pipe attached to the fitting. I made it from a piece of aluminum pipe. It can be cut with scissors.
A small piece of angle held the left side of the pipe flush with the back of the roaster.
The brass machine screw just pinned the flex pipe to the fitting.
LMWDP #280
Running on fumes.
Running on fumes.
