How to level grouphead?
wearashirt
#1: Post by wearashirt »
Hi all,
I would like to know how to perfectly level the stand of my espresso machine, and thus the flow of water from the group head and screen.
What I mean is, I've been trying to use a spirit level and my machine's adjustable feet, but it seems that the level I see doesn't correspond to the angle of the grouphead. Particularly, the water flow from the screen is eccentric from the dispersion screw.
Is the machine level my problem? Or do I need to buy competition-grade screens (and baskets)?
weebit_nutty
#2: Post by weebit_nutty »
If water flows unevenly from your group, the first thing I would inspect is the dispersion screen, and then go from there. You seem to be working backwards.
Remove your dispersion screen and take a good look. Maybe you've got a clogged screen, or maybe you have a soiled dispersion block.
Advertisement
FirstBetta
#3: Post by FirstBetta »
You might also check your distribution. Is there any channeling/spritz etc., is the puck level after tamping?
spearfish25
#4: Post by spearfish25 »
I can't imagine a few degrees matter once the puck is under 9 bar of pressure.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
HoldTheOnions
#5: Post by HoldTheOnions »
It will take the path of least resistance regardless of angle. Gravity is a weak force. I learned that on youtube.
