What's Your Charge Temperature? - Page 13
- Boldjava
I view turning point as more of a data point than a roasting target.Ladrex wrote:...
In artisan my lowest turning point I've been able to achieve is 113*C.
I think you might benefit by doing full 1K charge rather than 575g. Partial charges will bring back less consistent/accurate thermocouple readings.With a drum capacity of 1kg I dropped 575g at 170*C...
The 15:45 drop seems excessive long, in my opinion.Each progressively longer 1)12:00, 2)13:30, 3)15:45.
This is rather machine dependent. Soft air during drying, mid air during caramelization, and high air during development.How do others with drum roasters approach heat and air adjustments in the context of the 50/25/25 targets? Are there specific times that are better for these adjustments and what amounts do you adjust by at what points in the roast?
LMWDP #339
LMWDP #339
Yes agreed. What I was trying to say that in order for me to hit 100*C at 3 minutes my TP would need to be below 100*C and since my lowest has been 113*C I'm not sure I can achieve that.Boldjava wrote:I view turning point as more of a data point than a roasting target.
However, I will try a full load 1kg as you suggest. So I'll see how that will change things. I think I'll need to up the drop temp by 10-20*C if my batch is going up in size nearly 50%.
- endlesscycles
You fly blind until a bit past the TP.
-Marshall Hance
Asheville, NC
Asheville, NC
JK wrote:Anyone ever take Boot's $499 coffee course?
Just wondering if someone that took the course has an opinion on it..
$500 is a lot of beans
You get what you pay for: yes, the freebies are useless. But the BootCamp course is OK and the CoffeeCourses is much better. (https://coffeecourses.com/) Lots of useful practical information on lots of topics. Helped me a lot and was worth the money.
~Arch
- JK (original poster)
Thanks Arch,
I was wondering if it was worth it..
I'm on a Mission from God!
Looking out of a window, there is a tree. If we turn our head away from this window, we couldn't see this tree. The question is, is the tree still there while we are not watching?endlesscycles wrote:You fly blind until a bit past the TP.
Do we really fly blind if we don't have precise BT reading in the first couple minutes of a roast? Or, "it" must be there.
Batch coffee roasting; roasting energy use; reducing that use
Henry Schwartzberg
