Macap M7D for single dosing? Grind retention with hopper?
For those that own or have used a macap M7D, can you tell me how well suited it is in terms of single dosing without modification?
Also if operated with a few days worth of beans in the hopper, how much grind retention would you expect and need to be purged with a long idle time or grind adjustment.
thanks
thanks
- uscfroadie
Merle
- Compass Coffee
I think OP question a bit different, at least the 2nd part i.e. operating with beans in hopper over course of a few days with long periods between grinding. That scenario terrible, want to purge at least a half shots worth if sitting over night. In our cafes have single dose timed for half-cafs, use it for morning purge. If sitting idle more than an hour or so we use continuous and purge about 4-5 grams.
Mike McGinness
thanks. Between grind adjustments you would recommend this same amount, about half shot worth (10g)?
- Compass Coffee
Yes, however large conics need little adjusting same coffee. Once coffee dialed in adjust grind time more than grind during a day for environment changes etc. during a coffees run.HBchris wrote:thanks. Between grind adjustments you would recommend this same amount, about half shot worth (10g)?
Mike McGinness
