Can we plot an ideal delta BT in Artisan?
Here's what I'm thinking. My maximum delta BT seems to be about 40, usually at about 3 minutes into the roast. If I were to divide the minutes to the end of the roast(another 9 minutes or so) when I'd like my delta BT to be about 4, that would mean I'd like the minute intervals to be 40 - 36 - 32 - 28 (you get the picture). Is there a way to create an LED right under the actual deltaBT that shows the optimal BT for the same time frame?
- Arpi
Hi.
To get an LCD you need a virtual device. There are different ways to go about it.
You could do the deltaBT of a loaded background as a virtual device
You could do the delta of an Ln formula in a virtual device
You could do an explicit math formula in a virtual device.
For example, the derivative of the ln() function would be an explicit formula:
ln() formula: 232.56238380 * log(0.00715186 * t + 1.35120192, e)
the derivative is = 87626770037300/(376788234647*t +71186654393184)
You could use the plotter to find a formula you need. Then use it as a virtual device.
You could also use Designer to create a profile and then load it as a background and get an LCD through a virtual device.
Cheers
Cheers
Thanks Arpi. I must admit that my eyes kinda glazed over at the answers which are all somewhat over my head. I have been waiting to see if anyone chimed in with an "Arpi's answer for Dummies" for me. Until then or until I am feeling smarter than usual I will probably have to let this project slide.....But I thank you for paying attention to my query anyway ))
Susan
Susan
- Arpi
Hi.
The variable for the background BT is B2. If you load a background (with a desired BT), you can display the deltaBT of the background in an LCD with a virtual device defined with the formula:
60*(B2-B2[-1])/(t-t[-1])
Cheers
Cheers
I will work on that today when the roasting room thaws....
I'm not sure I agree with the idea of a linear drop in RoR. Mathematically it's sound, and may even be the ideal for certain coffees, but often I need to expand or contract different stages of the roast in order to emphasize desirable flavor characteristics or avoid others.
Yeah, I wouldn't trust it either as a control. I was just thinking of having it available as a marker; a benchmark?
