Cimbali m21 pressurestat - urgent
hello
before i make a mistake
i am going to switch machines with my friend , he have the cimbali m21 junior s
and i am having the quickmill aquila , i saw that the p-stat of the cimbali cost 270$ and it's not reliable.
is there a way to install a sirai p-stat because i heard that cimbali p-stat is low voltage
i dont know what that mean , does a regular p-stat will work at all .
does anyone did put a different p-stat other the original ?
do you think that switching to that cimbali is the right decision
thank you for your time and help
Hi,
I do not know any of the machine, but from basic view of photos on internet I do not see any reason to change from Quickmill to Cimbali. What is your reason to change? What is your intended use?
I see the Cimbali has rotary pump and volumetric measurement, Quickmill vibration pump, but in general they seem to be pretty similar for home use. I personally like more the Quickmill, because it looks better.
Changing pstat to other type should be not problem if you choose type with same (or higher) voltage and current rating.
