Recommendations another steam tip for Bosco Sorrento
fotomanufaktur
#1: Post by fotomanufaktur »
Hi everybody,
I got my Bosco and everything is fine, but the milk steaming. The Power of the Machine is unbelievable high?
Have someone recommendation for another steam tip for my Bosco?
Thank you very much for your help
cheers
Michael
dhb
#2: Post by dhb »
There is no thing like to much steam power. You can advance your technique to pro or use the highly recommend the Espro toriod milk pitcher. I use the 12oz on a 2 group Carimali for single cappuccinos. Still everything is happening fast.
Dirk
LMWDP #430
Espresso is simple, just not easy.
fotomanufaktur (original poster)
#3: Post by fotomanufaktur (original poster) »
I've talked today with Roberta and she told me, that they have different kind of Steam Tips. If you order a Bosco, you will get a 4-hole steam tip Ø 1,5 mm. The following additional Steam tips are available:
2-hole steam tip Ø 1,2 mm
2-hole steam tip Ø 1,5 mm
4-hole steam tip Ø 1,2 mm
So, Roberta send me all Steam tips and i can test which i more like. :-)
cheers
Michael
Nonineto
#4: Post by Nonineto »
Hi Michael.
I have a londinium l1 that I have yet to use, electrician has not finished the install. The bosco is the machine i really want. Yes your bosco has tremendous breathing capabilities due to the large boiler- btw, can you adjust boiler temp? This may help.
Can I see some pictures of your bosco??
Enjoy..
