Quickmill Vetrano 2B steam pressure drop with 4 hole tip - Page 4
I think it can work that way, but it is riskier because it doesn't take long to burn out a rotary pump if run dry. I haven't talked to anyone who recommends not using the flojet. Mary at Chris's Coffee did not recommend trying it without some sort of pump to provide pressure in the line.ruthlessaz wrote:Good to hear you like it! I would like to plumb it also eventually. Do the felt sliders help? I didn't out them on it, but maybe I should. I would suggest buying the 3 izzo tip set from CCS. There are 2 different 4 hole tips and a 3 hole( same exact size as the 2 hole it came with, but the holes are smaller than the stock 4 hole which hey with the steam pressure drop.
I am wondering if I put a 5 gallon bucket under the sink, and I put it in plump mode, will it work like that? Do you need to have a flo jet?
The felt sliders make a huge difference, sliding around is really pretty easy with them.
I have only had the machine a little over a week now, so I am still learning the 2 hole tip. I will likely try some others though, just for curiosity sake.
After procuring a GB/5 steam arm and playing with an LWW Steam Dial for a week, I've ordered the Izzo 3 pack from Chris' Coffee. At this point, I have more steaming options that I know what to do with.
Hi everyone. My first post here. I've been playing with espresso for a few years now. I have owned a Lucca M58 for a year and I agree with ruthlessaz...get the Izzo tip set. I've never been happy with the milk frothing performance of my machine even running in 20 amp mode. Even the 2 hole tip that came with it seems difficult to stretch the milk properly without getting soap bubbles. I finally plugged one of the holes in the 2 hole tip and got great micro foam, but it took a lot longer. Which was a bummer since thats a big part of the reason for getting a machine of this caliber. Just got the Izzo tips, installed the 3 hole one and perfect micro foam with much less boiler pressure drop and a lot faster than my old 1 hole approach. Also, it is really easy to get a nice vortex going. These tips should be what comes with both the Vetrano 2B and Lucca M58 IMHO.ruthlessaz wrote:Good to hear you like it! I would like to plumb it also eventually. Do the felt sliders help? I didn't out them on it, but maybe I should. I would suggest buying the 3 izzo tip set from CCS. There are 2 different 4 hole tips and a 3 hole( same exact size as the 2 hole it came with, but the holes are smaller than the stock 4 hole which hey with the steam pressure drop.
Yes, those izzo tips rock, I use the 4 hole, even though the pressure drops, by the time you are done with your milk, its all good, you don't need more pressure at the end. But I still love the 3 hole as well
Just wondering what the hole size is on the 3 pack of izzo tips? .8mm?
Not sure, but I use the 4 hole from izzo set... better than the stock 2 and 4 hole tips for sure. Steams quick. 3 hole is also good, takes a little longer though
