Lever hunt
So after picking up the HG-ONE I'm now on the hunt for a lever machine.
I'm enjoying the "analog" experience.
So right now I'm using a Profitec Pro 700 which is great! No complaints at all but I'm toying with the idea of running a lever.
I'm considering the Londinium 1 but the vibe pump has me slightly concerned, no particular reason but after my dual boiler/rotary pump I kinda see it as a downgrade. Silly I know because it's actually doing a different job. Why is there no insulation on the tank? Seems like everyone else makes a great marketing point about this.
I've looked into the Bosco which seems really nice and old school but another option I came across is a used Bezzera B2000AL. Haven't seen it yet but from what I can see it seems like a great machine in great condition.
Right now I'm running off 110v and built in tank but I plan on running 240v and hard plumbed so the used commercial is still viable.
So I guess what I'm asking is which machine? Right now I only "pull" 3-4 shots a day and I leave it on 24hours. The Bezzera is a 2 group 11l boiler, way overkill but priced around the same as a new Londinium and $1000 less than a Bosco.
You can also check the Salvatore Compact Spring Lever made in the US by Salvatore. $2400usd. It is a great machine, but two springs in the group compare to a single spring on the Londinium. I love theses commercial spring lever plumb in machine and i think you made a good decision and it will be a nice setup with an HG-One.
Also, if you buy the plumb-in kit with the L1 you will not use any pump.
Love, love, love my Bosco. I also considered the L1 and am very glad I held out for the Bosco. It's a beautiful machine, elegant in its simplicity and is a hand-made work of functional art. Mine is 110v, which is just fine as I leave it on 24/7. No vibe pump, silent, plumbed in and out. The size of the machine is a plus to me, may be a negative to some. I love the size and workspace of the drip tray. L1 would be way too cramped for my liking.
Personally, I love handmade things and enjoy them more. They've been building the same machine for 50 years. It's like getting a Model T handmade by Henry Ford.
Matt
Matt
- JohnB.
That Bezzera looks to be using their version of the older, smaller group that Bosco & others moved away from in late 2010. Having owned a Bezzera lever (Strega) I can say that I am much, much happier with the shots that I get from my Bosco.gowyn wrote: So I guess what I'm asking is which machine? Right now I only "pull" 3-4 shots a day and I leave it on 24hours. The Bezzera is a 2 group 11l boiler, way overkill but priced around the same as a new Londinium and $1000 less than a Bosco.
Bosco will build you a machine in either 120v or 230/240v so no need to upgrade the household wiring unless you want to.
Each Bosco incorporates everything Senor Bosco & his staff have learned about building levers since he started the shop in 1960. The machines are constantly evolving internally & are built to stand up to all day use in a busy cafe. I believe that they are the only company that's currently using that large group that installs a 4 seal piston & silicone seals. I'd consider it a definite step up from either of the other two machines that you are considering.
LMWDP 267
Been in contact with Bosco and am really liking what I'm hearing. Almost like ordering a Porsche, everything is optional so truly a custom built machine.
Quite excited about it.
A Bosco may very well be the last machine I order, especially if it's that custom but for now I'm still considering the used Bezz, it's the B2000AL pre 2004 I believe whatever that means.
