How to recharge water softener cartridge? - Page 2
- Peppersass
- Supporter ❤
If you have very hard water, over the long haul it's more economical to use a rechargeable softener, like these.
I bought a lifetime supply (40 lb) of the recommended salt pellets at Home Depot for about $5.
That is a cation exchange softener that is in the sodium form and is salt regenerated. That would be identical to the common whole house softener. If you are attempting to initially start the custom water process from a base of pure water you will have to add an anion exchange section and for best results a mixed bed polisher section. Some of this can be accomplished with the RO systems. Ultimately I suspect that a distiller and whole house softener will be both lower cost and easier to operate and maintain.
thank you for reply
my water PPM is very high at 270 PPM
My water readings:
Before Filters After Filters
270 PPM 280 PPM (TDS-4)
7.6 PH 7.6 PH (pH kit)
KH 12 drops 12 drops (GH & KH kit)
GH 14+ drops 1 drop (GH & KH kit)
looks like I have multiple options:
1. commercial softener system for about $300 - 2 filters replacement and recharge every 6-12 months $20
2. RO for about $200 - filters and membrane replacement every 6-8 months $30-$80
3. buy dist water from water store $0.25/Gal
4. existing 2 filters system - every 3-5 months cartridge replacement $30
what to do?
My water readings:
what to do?
Best Regards.
Mike.
Mike.
To your list should be added a softener designed for user recharging. Softeners of that design are not replaced; they are recharged using salt. See Post #11 in this thread.mikek753 wrote:looks like I have multiple options: . . . what to do?
-- Richard
Resin exchange home/consumer units load the outlet water up with sodium and that shows up on the TDS which makes TDS readings less than useless. If you want to start with pure water then go buy a home distiller. Output is pure water in a basic unionized state but it does need to be buffered slightly to raise the Ph to 7+.
yes, that is option #1Richard wrote:To your list should be added a softener designed for user recharging. Softeners of that design are not replaced; they are recharged using salt. See Post #11 in this thread.
no, resin will not be replaced, but other 2 filters will need to be replaced
Sorry, I wasn't clear
Best Regards.
Mike.
Mike.
- yakster
+1 on this, the test kits that I've seen to determine if the water softener is working test sudsing to see if the water is hard or soft, but a conductivity TDS meter won't show anything useful.OldNuc wrote:Resin exchange home/consumer units load the outlet water up with sodium and that shows up on the TDS which makes TDS readings less than useless.
-Chris
LMWDP # 272
LMWDP # 272
- JohnB.
The TDS readings for my hard water & softened water are always pretty much the same.
LMWDP 267
+1
only GH test results shows me difference
I think I'll use only GH number of drops to determine when to replace softener or recharge if I'll buy CC rechargeable softener
I can't evaluate total cost for 5 years and 10 years
Best Regards.
Mike.
Mike.
Reading comprehension failure on my part.mikek753 wrote:yes, that is option #1
-- Richard
