La Marzocco Linea Mini Update
- keno
Just a quick update for Linea Mini owners and those considering a purchase.
First, I heard from LM that the plumb in kit is expected to arrive in the U.S. next week, meaning that it has shipped from Italy. Leave a little time for them to get it out to dealers but it definitely will be available later this month. I didn't hear anything about the price but this post gave an expected price of $125.
Second, the current batch of machines are out of stock at LM and supplies are very limited at dealers, but not to worry the new shipment is due to arrive in early November and should be ready to ship in mid November. So new machines will be available before the holidays.
Finally, still no availability on the LED light covers. They are still working on this and hopefully will have a solution for users who would like to dim the lights.
- TomC
I've used dark tinting transparent paint on badges and turn signals of cars, I'm sure if the LED insert can be popped out easily, they can be carefully tinted quite a bit to tame down the intensity. Heck it would look like a factory job.
- keno (original poster)
Good suggestion Tom, I'll have to keep that in mind as an option if LM doesn't ever come out with the covers. As I'd prefer the covers over taking stuff apart and using paint.
Keno- any word on whether there will be any other updates/tweaks in the November shipment?
I've modified computers and other entertainment area equipment LED's with in line resistors. Snip the connection, drop in a variable resistor/potentiometer and dial it to the brightness you like. Then measure the resistance on your variable and solder in a similar spec resistor, cover it all with heat shrink tubing.keno wrote:Finally, still no availability on the LED light covers. They are still working on this and hopefully will have a solution for users who would like to dim the lights.
Whether La Marzocco thinks that's a problem mod I don't know, but it shouldn't be an issue as long as you do it cleanly.
LMWDP #445
According to LM, there are no changes to the Linea Mini. It's the same machine as the those from the prior shipment. So no reason to hold off if you are in the market for one.LATrapp wrote:Keno- any word on whether there will be any other updates/tweaks in the November shipment?
Just noticed this pdf that refers a little to the plumbing kit:
http://home.lamarzoccousa.com/wp-conten ... eamini.pdf
Actually for my use I am a little concerned with the pressure and flow-rate requirements. I have well water, so pressure fluctuates. Also, I will not be close to 2 GPM with my water treatment system.
On the other hand, my water system has worked fine for my Vivaldi. I wonder if the requirements are actual or recommended. Guess I won't know until I try it. (Could always fall back on the reservoir I suppose)
