Mazzer Mini - binds due to paint on adjustment threads...
Hi,
Ive just painted a mazzer mini and managed to get some paint overspray on the adjustment threads (on the body of the grinder) The collar will go on, make about 2 turns and then lock up completely.
Any suggestions on how to clean them properly without causing any damage?
12steps wrote:Hi,
If its paint use paint remover, eats paint.. Then pressure wash it if you can or clean with it with a cloth then air dry it.
Thanks -- will give it a go with paint stripper this weekend
- Randy G.
Gloves, a microfiber rag, and lacquer thinner or acetone. Dampen rag and rub.
That will even take off powder coating.
