Swamp Collie Coffee - We Need A New Roaster (Kickstarter) - Page 3
- woodchuck (original poster)
Patrick thanks very much for the link to the KapoK roaster. It looks good from a quick peak at the link you posted. I'll investigate further.
Cheers
Ian
Cheers
Ian
Hey Fern, I tried the thermal sensor mod but no luck. Maybe my timing isn't quite right on the switch. I didn't have a momentary around so just used a standard switch. If I click and release both switch and start button too fast it just starts to cool down as normal. If I do the thermal switch a little longer I get an et error. Any ideas.ciel-007 wrote:Take a look at the mod called "Cracking the 168F Barrier" explained at the link below:
Fern
Thanks
Ian
I think I figured it out. Opening up the one lead of the Thermocouple is giving it a max reading not a minimum. Guess maybe I should have shorted the two leads instead.
Cheers
Ian
Cheers
Ian
