Cleaning a boiler that has pinholes - Page 2
- grog (original poster)
If the element has leaked out magnesium oxide powder, can I render the boiler food safe with mild detergent or do I need something stronger?
LMWDP #514
Magnesium oxide is what is in most of the magnesium tablets and milk of magnesia.
Ha! Maybe I will just leave it there and allow it to help settle my stomach.
LMWDP #514
I would clean and inspect the inside of that boiler as it sounds suspiciously like scrap copper.
- Randy G.
If it was a pinhole in a braze or weld, and just one, I would likely silver solder it. But multiple holes in the body of the boiler? That would worry me. It's not like a little worm got in there and ate its way out at one isolated place. A burst boiler, even if not an explosive event, would spray hot water and steam and that thought alone is enough to make me go boiler shopping.
I've had it in daily use for about a month - it's on a timer from 5:45-6:30 am for my pre-work shots. 45 minutes of use each day and the boiler looks exactly the same inside as it did when I last had it apart...when I undertake the asbestos removal, I'll address the pinholes using one of the aforementioned methods.
LMWDP #514
- zeb
Just my 2 cents...
If the holes are in the neighborhood of the failed heating element, I'm quite sure that they are due to electric arcs.
Give this boiler to a professional to weld it. It is safer and more hygienic.
