Mazzer Major no longer grinding fluffy - Page 2
Yeah, it would seem normal to me if I hadn't cleaned the grinder in 2 months.. but I just removed the burrs yesterday and it's already like that.trumz wrote:Thats a normal ampunt of coffe under the burrs... Try and get some quality macro pics of the burrs for us.
- TomC
When I ever bother to getting around and putting the Major back together, I won't have to worry about that ground coffee getting caught up under those mount areas like that. Frank (Terranova) used to make a few spacers for Majors (just toying around, not something in production) but I bought his last set that should prevent this mess.
Based on experience with my mdf, I don't think it really matters too much how long it has been, once you grind some beans those spots will fill up. With more time it would perhaps be a bit more caked on but essentially the same I think, no?
Old burrs fixed it.. I know counter to what you would think. In fact, it's actually much faster with the old ones.. Less gushers too. Should hold me out until I get new ones in the mail.
I'm not sure why you think that there should be little to no grounds under the bottom carrier. In fact, I would guess that the fluffier the grounds the more easily it gets under the carrier. I just cleaned mine out and checked it again after 1-2 days and it has as mush as it did when I cleaned it out. I like the idea of a spacer though. I use thin strips of adhesive foam tape on my doser. This could work her as well or maybe even some of the soft-side of some Velcro tape.
- ravco
I wouldn't worry about the grinds under the burrs. Seems normal to me too.
Got a little stone in my major while grinding in my new burrs (was using cheap coffee ). It made such a loud bang, I thought the grinder was exploding. There are a few small nicks and scraches on the burrs now, but function seems normal.
Dont worry about the grinds under the burrs its normal on Mazzer's
All my Mazzer's had the same amount under the bottom Burrcarrier. SJ,Major,Koni,Robur.
I Think its a design thing'i there is simply to mutch space under the carrier.
Great to hear your back in business untill new burrs arrive.
/Uldall
/Uldall
Bassethound.
Coffee Driven.
Coffee Driven.
