Astra Pro espresso machine replacement water pump
I just picked up a astra pro espresso machine and the water pump is leaking. Right now it has a fluid o tech water pump like
https://www.espressoparts.com/110v-70w- ... atory-pump
is that the only option and most durable pump? Or should i get a ulka pump off ebay?
Any help is appreciated.
Matt
Matt
- erics
- Supporter ★
Then you should post a pic of the machine's internals and indicate where the pump is leaking. More than likely, it is a fitting which simply needs some minor disassembly and resealing.Any help is appreciated.
The FOT pump and the Ulka have different flow characteristics.
