Leaking Quickmill Alexia After Portafilter Gasket Replacement
HI - I have a Quickmill Alexia PID which produces perfect shots, I did the annual portafilter gasket + screen replacement and used the recommended 8.5mm gasket, with the new set up the seal leaks a bit when pulling shots and the puck is wet when I take it out. This was never an issue with the previous gasket. So I ordered and installed a 9mm gasket, still using the new screen, but the filter doesn't come close to being at 6 o'clock when engaged. Any suggestions?
Did you put it in the proper direction ? There is a top and a bottom to the gasket.....There is a slight taper to the gasket. The narrow side goes up.
A couple times after changing gaskets they would leak until the gasket seated itself but most of the time they seal correctly.
not sure which direction it put it in, will check and re-do if necessary
thanks for the help!
I have the same Alexia and have found that not all 8.5 mm gaskets are the same. Some are harder or softer. They compress more or less. Getting the handle to 6 o'clock is nice, but not always possible. You may end up trying many gaskets.
D.
D.
HI I am finally back home and tried this, I had it upside down. Putting the narrow end up does stop the leaking, but like the other member, with the 8.5mm I go past 6 o'clock. I have a 9mm which has me at about 5 o'clock. Well, at last no leaking now. Thanks for all your help
