Nuova Simonelli Oscar mod. from Slovenia
- d_leonit
I decided to open a topic, that i can show a litle bit more of my Simonelli Oscar modifications:
Modifications:
- Rotary pump:
CA104 fluid o tech pump 100 l/h
motor RPM 120W
- exterior 5l tank with water level sensor.
- restrictor for HX in group head (stabilize the temperature as on Simonelli Musica)
Gigler M8x8 F. 3
Gigler M8x8 F. 3,2
- manometer for brew pressure and steam pressure
- Electronic Preinfusion (ON-OFF-ON...timer is adjustable T1,T2,T3)
- restrictor for lowering of watter flow in group head M6 0.5mm and before HX M6 0.5mm (80ml/10s) ( must have, because rotary pump have much higher flow)
- vacuum breaker
- Shower IMS SI 200 IM
- different steam tips
Oscar and Major
rotary pump and OPV in the box
box outside (tank side)
box inside with tank
Bottom of the Oscar with cable and water connection from oscar to rotary pump
front panel with manometers
Oscar inside with manometer connections
Changing of retaining valve
steam tips
Modifications:
- Rotary pump:
motor RPM 120W
Gigler M8x8 F. 3
Gigler M8x8 F. 3,2
- vacuum breaker
Oscar and Major
steam tips
- baldheadracing
Very nice!
What hopper is on your Major? Looks perfect for me. Nice mods BTW! Just sold my Oscar.
Jam funnel ??LukeFlynn wrote:What hopper is on your Major? .....
http://www.meilleurduchef.com/cgi/mdc/l ... unnel.html
- d_leonit (original poster)
That's right i bought it in Müller, cost me 6EUR
- bluesman
Thanks - that's a beautiful and inspiring project. Well done!!
- plindy
nicely done
location of M6 reducer in group head and before HX ?
One is before retaining valve (before HX), second is after HX in group head (before 3 way valve) ...plindy wrote:nicely done
