Please help! Is my rotary pump failing? - Page 2
First, thank you so much for the help!
I checked both solenoids... (plumb and reservoir) and even switched them... still no water pulling in... water isn't pulling past the large particle filter (which I just changed too). Is it possible pump is seized?
Is there any way to check that it is for sure the pump?
Any ideas?
Any ideas?
"new grinder? Tell me more..."
Ok, it's working again... but I have a question.
Turn machine on, warms up... the right "bars" gauge is at zero... when I lift the lever it jumps to 8 bars. As it engages the coffee it jumps to 9 ish bars... all seems normal... when I end the shot... it does not drop back to zero but rather somewhere around 4 bars.
Is this normal? Or is it indicative of a problem?
I thought I remember it dropping back to zero before I did everything I've done to fix it.
