Astoria argenta 2 group repair help
Having issues repairing this machine. Are there any Astoria experts that can help me out???
- erics
- Supporter ★
Some helpful manuals for that machine are here: /downloads/
The "experts" would surely expect you to define the issues you have.
the issues that I am having involve lack of dispensing pressure. The group head spits and sputters and doesn't have constant flow. The left side does not dispense at all and the pump is functioning properly. I have had every piece of plumbing and all connectors removed and cleaned. What I want to try and figure out is how to trace the problem to the source...because all hydrolics appear to be working properly and I have found no blockages. this machine is actually a devina not an argenta as previously mentioned. I have two machines that I maintain...This machine has previously worked perfectly as it was in my café and I took very good care of it.
Sounds like you already checked for obvious scale by going through the plumbing. If you're completely confidant there should be no blockages, I'd check the three way valve. Semi dead solenoid coil or something mechanical with the valve can certainly do what you describe.
From memory I can't recall if CMA machines tend to use gicleurs, though you might have checked that already.
