Please help with astoria 2 group, no pressure
I just got this machine.
The condition is partly working.
the left stream not working but i think it might clog some where in the tube , i will check it out later (the right one working , middle working as well)
took both brew head off and i can see the water coming out once i hit the manual switch (but im not sure it should be more water coming out? The stream came out from brew head either)
once i see that they have no clog on brew system , i put
2 new heads from my stock , looking good now.
But after i push the manual switch, water came really little.
I looked the the pressure , no there are 0 bar.
I checked the pump , working normal , still spinning , so im not sure its on the 2 way on the pump?
So i track the line and i saw some valves , i really dont know that it should be open or not but once i did turn.
Water hazard now!
Is it because of this ? Thats why it have no pressure? Or its because the 2 way water line at the pump?
Water hazard now!
