Mazzer Super Jolly - kg through burrs before replacement?
Hi folks.
Just replaced my burrs.
My question is, how much bean would you put through before you think it's time to replace again?
Any idea what good espresso bars practice?
Thousands of kg?
In other words, what is the expected lifetime of the burrs, based on kg of beans ground?
Thousands of kg?
- HB
- Admin
According to the Mazzer owner's manual:
I don't know the replacement policy of top espresso bars; I recall informed guesses from previous discussions suggesting half the manufacturer's recommendations. How to know grinder burrs are worn out? offers wear indicators like coffee overheating/clumping, having to grind finer and finer, shot volume decreasing before blonding and grind time increasing. Specifically for the Super Jolly, the burrs are very reasonably priced, so there's less motivation to push them to the very end of their useful life.When using coffee blends of average hardness, it is advisable to replace the grinding blades approximately every:
600 kg for the Major model
400 kg for the Super Jolly model
300 kg for the Mini model. (approx. 660 pounds)
I just saw this and wanted to make sure I understand this correctly. I don't grind so much coffee, approximately 1kg per 4 weeks or less.
I have a SJ, so this gives me 400 * 4 weeks = 1600 weeks or ~30 years before I need to change burrs. Would you say that this is correct? If yes, then 29 years from now, I think I can just buy a new grinder all together
Your math and coffee usage match the calculation I recently did
30 years, seems impossible....i also wondered if that would be possible, think it is with regular use, but I somehow expect other vitals parts to die before the burrs are worn...
LMWDP #483
- HB
- Admin
Your estimates look correct based on home usage. Keep in mind that your Super Jolly is a commercial grinder designed for use in a cafe. A typical cafe goes through more coffee in a month than most of us would in years.
Thanks Dan. User manual...great idea...didn't occur to meHB wrote:According to the Mazzer owner's manual:
400 kg =1600 x 250 g bags. I'm also at about 1 bag per week, i.e. 30 years before replacement.
Having said that, my espresso is definitely more nuanced after replacement. So I'm with Dan, for the cost I think 5 years is reasonable.
