The effect of pre-infusion flow-rate on brew temperature profile
- indend007
I have tested temperature stability on KvdW Speedster last 3 day, and found pretty long ramp-up time on it.
I wonder why a ramp curve like this was drawn, so I suspected something was up with pre-infusion.
Speedster's has quite long pre-infusion duration with it's own PPIC(Progressive Pre Infusion Cylinder).
So, I did temperature test on my GS/3 MP under two phase ;
#1. Standard extraction.
#2. 15 seconds extraction under full pressure 9bar after 10 seconds 3 bar pressure tap water Pre-infusion.
I got a average data from 10 times extraction test on each situation ;
Totally, it is summarized on same graph "Speedster's, GS/3 Standard flow and with P/I".
On pre-infusion phase, GS/3's ramp curve move toward to Speedster's curve (But not exactly same shape).
GS/3 with P/I shows more slow temperature ramp speed than standard flow, we can suspect that is caused by flow-rate and thermal energy.
If we try make shot using pre-infusion, maybe it was attended with much different thermal energy.
Note :
* Speedster's initial ramp-up duration is about 10 seconds.
* Both Machine are setted to 95 Celsius, but there are different offset. So, for convenience I re-adjust final temperature to 93.0 celsius.
Follow : https://instagram.com/indend007
- shadowfax
Devin, thanks for doing this very interesting test. For those unaware, Devin did this work based on the Modified procedure for measurement of brew water temperature that I posted about today. I had shared this procedure with him privately last week when I saw that he was using a Scace on his Speedster on Facebook.
I haven't logged the data, but I see a really similar effect with the Slayer, which is to say that using pre-brew when doing shot simulation results in a noticeably slower rise to temperature than going straight to full flowrate ("brew") mode. It's a really interesting dimension to "flow profiling," and I was surprised to see how much it was "baked in" to the Speedster's temperature profile (that is to say, it can't be avoided without disabling the preinfusion chamber).
I definitely feel like this could be one explaining factor in how shots with very long (20s+) pre-brew times don't seem to cook or over-extract-even though the brew time is extended, the average brew time is effectively dropped.
Nicholas Lundgaard
- JohnB.
And hopefully no one would ever want to do that. Kees discusses the pre infusion features built into the Speedster here: http://www.keesvanderwesten.com/speedst ... ction.html As I've mentioned a number of times previously many of the profiles I see Slayer owners, modified GS3 owners & others posting about are designed right into the Speedster. A slow, low pressure pre infusion is a key element of the Speedster's design so it shouldn't be surprising that the temperature ramp is slower then what you would see in a conventional pump machine. Whether you select manual P/I or Pump the puck will be soaked with a gentle low pressure shower before the pressure ramps up.shadowfax wrote: It's a really interesting dimension to "flow profiling," and I was surprised to see how much it was "baked in" to the Speedster's temperature profile (that is to say, it can't be avoided without disabling the preinfusion chamber).
LMWDP 267
- shadowfax
I love being able to to grind fine and do 20+ second pressure ramps. That said, not every coffee benefits from this strategy, and many are outright terrible with it. There's something to be said for a fast ramp with certain styles of espresso.JohnB. wrote:And hopefully no one would ever want to do that.
Nicholas Lundgaard
- JohnB.
In which cause you simple select the Speedster's pump function & get a 4 second ramp to full pressure.
LMWDP 267
